Colors like you've never seen before. Philips E-line monitor features Color IQ Quantum Dot technology, an advanced nano-technology that produces the richest and most vivid colors.
MHL technology for enjoying mobile content on a big screen
Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway. -
SmartContrast for deep black level details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
Modern Touch controls complement the design
Touch controls are intelligent, touch-sensitive icons that replace protruding buttons to allow users to adjust the monitor to their requirements. Responding to the lightest touch, Touch control gives the monitor a modern feel. -
IPS-ADS wide-view technology for image and colour accuracy
IPS-ADS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-ADS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
Quantum Dot Tech for see-it-to-believe-it colour
Quantum Dot Technology is an innovative semiconductor nanocrystal technology that precisely emits light to produce bluer blues, greener greens and redder reds. LCD monitors with Quantum Dot colour produce a more dynamic range of colours and show the true natural palette of colours in the picture. The result - vibrant, dynamic, see-it-to-believe-it colour. -
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture. -
Pro colour standards 99% Adobe RGB, 100% sRGB
With professional industry-standard colour coverage 99% Adobe RGB and 100% sRGB colour gamuts, you can have confidence that your colour is consistent and true.
- Philips E-line 276E6ADSS - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 66 kWh
- Power Consumption (On mode)
- 45 W
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 14 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB, 99% Adobe RGB
- Input Connectors
- DVI-D, VGA, HDMI (MHL)
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Glossy silver
- 64 cm x 23.5 cm x 47.1 cm
- 5.33 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, CEL, cETLus
- Display Type
- Energy Class
- Class C
- 66 kWh
- Diagonal Size
- 27"
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, SmartImage Lite, SmartResponse, SmartContrast, WideView, Touch Control, SmartControl Lite, Mercury free
- Glossy silver
- 64 cm x 23.5 cm x 47.1 cm - with stand
- 5.33 kg
- VGA , DVI-D (HDCP) , MHL / HDMI (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- MTBF
- 50,000 hour(s)
- Input Voltage
- 45 W
- Power Consumption (Typical)
- 25.89 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- On / Off Switch
- No
- OS Required
- Apple MacOS X, Microsoft Windows 7 / Windows 8
- Dimensions & Weight Details
- With stand - width: 64 cm - depth: 23.5 cm - height: 47.1 cm - weight: 5.33 kg , Without stand - width: 64 cm - depth: 4.8 cm - height: 39 cm - weight: 4.57 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
