See detail like never before with Philips 5K UHD monitor. 14.7 million pixels provide razor sharp visuals for your most detailed work. PerfectKolor technology ensures accurate and consistent color every time.
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Webcam with mic to connect and collaborate
Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel-related costs. -
USB 3.0 enables fast data transfers and smart phone charging
Super-Speed USB 3.0 deploys a 5.0 gbit/s transfer rate, which is about 10 times faster than the USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use large-capacity storage devices. Sync-N-Go technology ensures you don't have to wait for bandwidth to be freed up any more. Your investment in USB 2.0 devices is protected as it is backwards-compatible. -
PLS LED wide-view technology for image and colour accuracy
PLS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle - even in 90-degree Pivot mode! Unlike standard TN panels, PLS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
SmartUniformity for consistent images
Fluctuations in brightness and colour on LCD screens are a common phenomenon. Philips' SmartUniformity mode delivers accurate images in terms of brightness; which is crucial for photography, design and printing. With a colour metric to assess colour accuracy, this mode is calibrated to meet average luminance uniformity of more than 95%. Selecting this mode will produce uniform and accurate images. -
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
1.074 billion colours for smooth colour gradations and detail
The 10-bit display delivers rich colour depth with 1.074 billion colours and 12-bit internal processing for recreating smooth, natural colours without gradations and colour banding. -
5K Ultra HD (5120 x 2880) resolution for ultraclear visuals
14.7 million pixels for precise detail and clarity. With 5K Ultra HD resolution, four times Quad HD, you see detail like you've never seen before for perfect results. -
Pro colour standards 99% Adobe RGB, 100% sRGB
The perfect colour, you know it when you see it. These new monitors feature high quality brilliant panels for rich accurate colour from every angle. Know that your colour is consistent with professional industry-standard colour, 99% Adobe RGB and 100% sRGB. Out of the box colour precision with factory colour calibration gives you confidence right from the start. Adjust the colour to your exact standards with six axis custom colour adjustment. Save time and money with Philips monitors with PerfectKolor Technology. -
- Philips Brilliance P-line 275P4VYKEB - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Microphone, 2.0 megapixel camera, USB 3.0 hub
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- 5K Ultra HD (2880p) 5120 x 2880 at 60 Hz
- Pixel Pitch
- 0.117 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 1.074 billion colours (10-bit)
- Colour Gamut
- 100% sRGB, 99% Adobe RGB
- Input Connectors
- 2xDisplayPort
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black, textured black/silver front bezel
- 63.9 cm x 27.3 cm x 58 cm
- 8.11 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, BSMI, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, cETLus, CU-EAC
- Display Type
- Diagonal Size
- 27"
- Built-in Devices
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.117 mm
- Pixel Per Inch
- 0.117
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 174 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, SmartImage, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free, PerfectKolor technology, SmartUniformity
- 63.9 cm x 27.3 cm x 58 cm - with stand
- 8.11 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- 2 x DisplayPort , 3 x USB 3.0 , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 70,000 hour(s)
- Input Voltage
- Power Consumption (Typical)
- 45.1 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- OS Required
- Apple MacOS X
- Dimensions & Weight Details
- With stand - width: 63.9 cm - depth: 27.3 cm - height: 58 cm - weight: 8.11 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.32 kg
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
