Philips 275P4VYKEB/00 27" 5120x2880 HDMI Monitor
Quicklinx: BYMPWS00 Mfr#: 275P4VYKEB/00
See detail like never before with Philips 5K UHD monitor. 14.7 million pixels provide razor sharp visuals for your most detailed work. PerfectKolor technology ensures accurate and consistent color every time.
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • SmartErgoBase enables user-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • Webcam with mic to connect and collaborate
    Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel-related costs.
  • USB 3.0 enables fast data transfers and smart phone charging
    Super-Speed USB 3.0 deploys a 5.0 gbit/s transfer rate, which is about 10 times faster than the USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use large-capacity storage devices. Sync-N-Go technology ensures you don't have to wait for bandwidth to be freed up any more. Your investment in USB 2.0 devices is protected as it is backwards-compatible.
  • PLS LED wide-view technology for image and colour accuracy
    PLS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle - even in 90-degree Pivot mode! Unlike standard TN panels, PLS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • SmartUniformity for consistent images
    Fluctuations in brightness and colour on LCD screens are a common phenomenon. Philips' SmartUniformity mode delivers accurate images in terms of brightness; which is crucial for photography, design and printing. With a colour metric to assess colour accuracy, this mode is calibrated to meet average luminance uniformity of more than 95%. Selecting this mode will produce uniform and accurate images.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • 1.074 billion colours for smooth colour gradations and detail
    The 10-bit display delivers rich colour depth with 1.074 billion colours and 12-bit internal processing for recreating smooth, natural colours without gradations and colour banding.
  • 5K Ultra HD (5120 x 2880) resolution for ultraclear visuals
    14.7 million pixels for precise detail and clarity. With 5K Ultra HD resolution, four times Quad HD, you see detail like you've never seen before for perfect results.
  • Pro colour standards 99% Adobe RGB, 100% sRGB
    The perfect colour, you know it when you see it. These new monitors feature high quality brilliant panels for rich accurate colour from every angle. Know that your colour is consistent with professional industry-standard colour, 99% Adobe RGB and 100% sRGB. Out of the box colour precision with factory colour calibration gives you confidence right from the start. Adjust the colour to your exact standards with six axis custom colour adjustment. Save time and money with Philips monitors with PerfectKolor Technology.
Philips Brilliance P-line 275P4VYKEB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Microphone, 2.0 megapixel camera, USB 3.0 hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
5K Ultra HD (2880p) 5120 x 2880 at 60 Hz
Pixel Pitch
0.117 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
2xDisplayPort
Textured black, textured black/silver front bezel
63.9 cm x 27.3 cm x 58 cm
8.11 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays, cETLus, CU-EAC
Display Type
Diagonal Size
27"
Built-in Devices
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.117 mm
Pixel Per Inch
0.117
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
174 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, SmartImage, 100% sRGB colour gamut, 99% Adobe RGB colour gamut, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free, PerfectKolor technology, SmartUniformity
63.9 cm x 27.3 cm x 58 cm - with stand
8.11 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x DisplayPort , 3 x USB 3.0 , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
MTBF
70,000 hour(s)
45.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Apple MacOS X
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 27.3 cm - height: 58 cm - weight: 8.11 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.32 kg
ENERGY STAR Certified
20 - 80%
BYMP C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.34
BYMP C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £7.85
BYMP C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYMP C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £24.05
BYMP C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.69
BYMP C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.37
BYMP C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.37
