Get the perfect results you're looking for. This professional IPS-AHVA display delivers CrystalClear Quad HD images. PerfectKolor Technology ensures factory-calibrated 99% AdobeRGB color space and a billion colors for perfect results.
PerfectKolor for exact results
The perfect color, you know it when you see it. These monitors feature high quality brilliant panels for rich accurate color from every angle. Know that your color is consistent with professional industry-standard color, 99% Adobe RGB and 100% sRGB. Out of the box color precision with factory color calibration and a factory calibration report give you confidence right from the start. Adjust the color to your exact standards with six axis custom color adjustment. Save time and money with Philips monitors with PerfectKolor Technology. -
10-bit colors
The 10-bit display delivers rich color depth with 1.074 billion colors and 12-bit internal processing for re-creating smooth, natural colors without gradations and color banding. -
SmartUniformity
Fluctuations in brightness and color on LCD screens are a common phenomenon. Philips SmartUniformity mode delivers accurate images in terms of brightness; which is crucial for photography, design, and printing. With a color metric to assess color accuracy, this mode is calibrated to meet average luminance uniformity is greater than 95%. Selecting this mode will produce uniform and accurate images. -
IPS-AHVA display
IPS-AHVA displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-AHVA displays give you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times. -
Crystalclear images
These Philips screens deliver Crystalclear, Quad HD images. Utilizing high performance panels with high density pixel count, 178/178 wide viewing angles, enabled by high bandwidth sources like Displayport, HDMI, Dual link DVI, these displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystalclear images. -
Flicker-free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. -
MultiView technology
With the ultra-high resolution Philips MultiView display you can now experience a world of connectivity in a comfortable way whether at office or at home. MultiView enables active dual connect and view so that you can work with multiple devices like PC and Notebook side-by-side simultaneously, making complex multi-tasking work a breeze. Watching live football feed from your set-top box on right side, while browsing the Internet from your notebook on the left is now easy. You may want to keep an eye on the live news feed with audio in the small window, while working on your latest blog. -
Webcam
Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel related costs. -
Built-in stereo speakers
A pair of high quality stereo speakers built into a display device.
- Philips Brilliance P-line 272P4APJKHB - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 76 kWh
- Power Consumption (On mode)
- 52 W
- 2.0 megapixel camera
- Panel Type
- AHVA
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 12 ms (typical)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% Adobe RGB
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black
- 63.9 cm x 24.2 cm x 58 cm
- 7.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, cETLus, CU-EAC
- Display Type
- Energy Class
- Class C
- 76 kWh
- Diagonal Size
- 27"
- Built-in Devices
- Panel Type
- AHVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% Adobe RGB
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Chinese (traditional), Chinese (simplified), Ukrainian, English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Turkish, Japanese, Korean
- Picture in picture, Sync on Green, sRGB colour management, SmartResponse, MultiView, SmartContrast, SmartImage, Smart Ergo base, Crystal Clear Quad HD, Flicker Free technology, Mercury free, PBP, PerfectKolor technology, SmartUniformity
- Textured black
- 63.9 cm x 24.2 cm x 58 cm - with stand
- 7.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- 3 x USB 3.0 , DVI-D (HDCP) , DisplayPort , 2 x HDMI , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- External
- Input Voltage
- 52 W
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- Included Software
- Philips SmartControl Premium
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
- Dimensions & Weight Details
- With stand - width: 63.9 cm - depth: 24.2 cm - height: 58 cm - weight: 7.5 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.1 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
