Product
Philips 272G5DJEB/00 27" 1920x1080 1ms VGA HDMI Display Port Monitor
Quicklinx: BYZ3WS00 Mfr#: 272G5DJEB/00
This advanced Philips gaming display redraws the screen up to 144 times per second for ultra smooth, brilliant images. SmartFrame helps you highlight specific screen area. Special gaming pre-sets and remote smart keypad keeps you in control.
  • 144 Hz gaming
    You play intense, competitive gaming. You demand display with lag free, ultra smooth images. This Philips display redraws the screen image up to 144 times per second, effectively 2.4x faster than a standard display. A lower frame rate can make enemies appear to jump from spot to spot on the screen, making them difficult targets to hit. With 144 Hz frame rate, you get those critical missing images on the screen which shows enemy movement in ultra smooth motion so you can easily target them. With ultra low input lag and no screen tearing, this Philips display is your perfect gaming partner.
  • MHL technology
    Mobile High Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
  • SmartImage game mode
    The Philips gaming display has quick access OSD fine tuned for gamers, offering you multiple options. "FPS" mode (First person shooting) improves dark themes in games, allowing you to see hidden objects in dark areas. "Racing" mode adapts display with fastest response time, high color, along with image adjustments. "RTS" mode (Real time strategy) has a special SmartFrame mode which enables highlighting of specific area and allows for size and image adjustments. Gamer 1 and Gamer 2 enable you to save personal customized settings based on different games, ensuring best performance.
  • SmartFrame
    SmartFrame enables you to spot your opponents easily by highlighting a specific area on the screen. By boosting the gain level of RGB in the selected area, it allows you to give more attention to that specific part of the screen where you expect sudden enemy movement. You can also adjust size and image to your preference. It is especially suitable for RTS- Real Time Strategy mode games.
  • SmartConnect
    With a plethora of connectivity, these Philips displays come equipped with multi connections like Dual link DVI, Display Port, universal HDMI connector, enabling you to enjoy high resolution uncompressed video and audio content. USB 3.0 option ensures that you can have super speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon!
  • SmartKeypad
    SmartKeypad is a specially designed remote controller that connects to this Philips gaming display. It enables fast and convenient access to your gaming presets with 2 quick key access buttons, allowing you to save and activate two personalized custom settings either for gaming or other purposes. With additional up and down function keys, you can now easily navigate in the OSD menu and settings directly.
Philips Brilliance 272G5DJEB - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
39 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured black
63.9 cm x 24.2 cm x 58 cm
7.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, cETLus
3 years warranty
Display Type
Energy Class
Class B
57 kWh
39 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 146 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartResponse, SmartContrast, Mobile High-Definition Link (MHL), Smart Frame, SmartConnect, SmartImage Game, SmartSize
Textured black
63.9 cm x 24.2 cm x 58 cm - with stand
7.5 kg
DVI-D (dual link) , VGA , DisplayPort , 2 x HDMI (HDCP) , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+25
Swivel Angle
130
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
SmartKeypad
MTBF
30,000 hour(s)
Power Supply
Internal
24.6 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 24.2 cm - height: 58 cm - weight: 7.5 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.1 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
BYZ3 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.31
BYZ3 C2G HDMI to DisplayPort Adapter Converter In Stock £37.46
BYZ3 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.65
BYZ3 C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.72
BYZ3 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYZ3 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.32
BYZ3 C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.20
BYZ3 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.75
BYZ3 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.89
