Philips 272B7QPTKEB 27" 2560x1440 5ms VGA DP mini DP HDMI Monitor
Quicklinx: C9Z1WS00 Mfr#: 272B7QPTKEB/00
The Philips PowerSensor display using 85% post consumer recycled plastics and PVC, BFR free housing is ideal for eco-friendly productivity.
  • Crystal clear images with Quad HD 2560 x 1440 pixels
    These Philips screens deliver CrystalClear, Quad HD 2560 x 1440 or 2560 x 1080 pixel images. Utilising high-performance panels with high-density pixel count, enabled by high-bandwidth sources like USB-C, Displayport, HDMI and Dual-link DVI, these new displays will make your images and graphics come alive. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions, are using 3D graphic applications or are a financial wizard working on huge spreadsheets, Philips displays will give you CrystalClear images.
  • IPS technology for full colours and wide viewing angles
    IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • Narrow-border display for a seamless appearance
    The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
  • LowBlue Mode for easy-on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • SmartErgoBase enables user-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • Webcam pops up when you need it; secures down when you don't
    Webcams are great for connecting with others and collaborating on that important project. Sometimes, though, you don't want a webcam looking down on your desk. Our ingenious new pop-up webcam design pops up when it's time for meetings and for security tucks away nicely when you are not using it.
  • DisplayPort-out for connecting additional displays
    With DisplayPort-out you can connect multiple high-resolution displays with just one cable from your first display to the PC. The ability to daisy chain multiple displays enables you to maintain a clean desktop without the hassle of too many wires.
  • SmartConnect with DisplayPort, HDMI and VGA connections
    With a plethora of connectivity, these Philips displays come equipped with multiple connections like VGA, Display Port and universal HDMI connector, enabling you to enjoy high-resolution uncompressed video and audio content. USB connections ensure that you can have super-speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon!
  • PowerSensor saves up to 70% energy costs
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
Philips Brilliance B-line 272B7QPTKEB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
26.2 W
2.0 megapixel camera, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort, Mini DisplayPort
Display Position Adjustments
Voltage
Textured black
61.4 cm x 25.7 cm x 54.8 cm
7.86 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, EPA, cETLus, Ukrain Safety, CU-EAC
Display Type
Energy Class
Class F
54 kWh
Diagonal Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 99 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
sRGB colour management, PowerSensor, SmartResponse, SmartImage, edge-to-edge glass, Smart Ergo base, SmartConnect, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Ultra Narrow Border, Mercury free, USB 3.0 Fast Charge, Wide Viewing Angle, Sync-N-Go
Textured black
61.4 cm x 25.7 cm x 54.8 cm - with stand
7.86 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort , Headphones , Audio line-in , 3 x USB 3.0 downstream , HDMI , USB 3.0 upstream , Mini DisplayPort , DisplayPort output
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x HDMI cable , 1 x Mini DisplayPort cable , 1 x USB cable
MTBF
70,000 hour(s)
Input Voltage
26.2 W
26.2 kWh/1000h
Power Consumption (Typical)
20.7 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 25.7 cm - height: 54.8 cm - weight: 7.86 kg , Without stand - width: 61.4 cm - depth: 5.6 cm - height: 37.2 cm - weight: 5.44 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
20 - 80%
