Philips 272B7QPJEB 27" 2560x1440 5ms VGA DP HDMI Monitor
Quicklinx: C9Z2WS00 Mfr#: 272B7QPJEB/00
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
Select:
Hurry, only 1 left in stock!
£266.66 ex VAT
£319.99 inc VAT
The Philips PowerSensor display using 85% post consumer recycled plastics and PVC, BFR free housing is ideal for eco-friendly productivity.
Philips Brilliance B-line 272B7QPJEB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
53 kWh
Power Consumption (On mode)
36 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (SmartResponse)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Textured black
61.4 cm x 25.7 cm x 54.8 cm
7.86 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TUV GM, EPA, cETLus, CU-EAC
Display Type
Energy Class
Class B
53 kWh
36 W
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 99 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
sRGB colour management, PowerSensor, SmartResponse, SmartImage, edge-to-edge glass, Smart Ergo base, SmartConnect, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Ultra Narrow Border, Mercury free, USB 3.0 Fast Charge, Wide Viewing Angle, Sync-N-Go
Textured black
61.4 cm x 25.7 cm x 54.8 cm - with stand
7.86 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort , Headphones , Audio line-in , 2 x USB 3.0 , HDMI
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x HDMI cable
MTBF
70,000 hour(s)
Power Consumption Stand by
0.3 Watt
On / Off Switch
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 25.7 cm - height: 54.8 cm - weight: 7.86 kg , Without stand - width: 61.4 cm - depth: 5.6 cm - height: 37.2 cm - weight: 5.44 kg
ENERGY STAR Certified
20 - 80%
Philips 272B7QPJEB 27 Bundle deal on Philips 272B7QPJEB 27" 2560x1440 5ms VGA DP HDMI Monitor
£365.83
C9Z2 C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.88
C9Z2 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.98
C9Z2 C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £8.08
C9Z2 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £24.74
C9Z2 C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £17.18
C9Z2 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.98
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 150 - 300
