Philips 272B4QPJCG/00 27" 2560x1440 DVI VGA Monitor
Quicklinx: BYPVWS00 Mfr#: 272B4QPJCG/00
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
£399.54 ex VAT
£479.44 inc VAT
This Philips PowerSensor LED display with PVC and BFR free housing, USB hub and ergonomic base is ready for eco-friendly productivity.
Philips Brilliance B-line 272B4QPJCG - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
65 kWh
Power Consumption (On mode)
45 W
USB 3.0 hub
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
12 ms (typical); 4 ms (grey-to-grey)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments
Textured grey
63.9 cm x 24.4 cm x 54 cm
6.72 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, SEMKO, TUV Ergo, DDC/CI, Lead-Free, WEEE, cETLus, CU-EAC
Display Type
Energy Class
Class C
65 kWh
45 W
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, PowerSensor, MultiView, SmartContrast, SmartImage, Smart Ergo base, Crystal Clear Quad HD, SmartConnect, Flicker Free technology, BFR/PVC-free, Mercury free
Textured grey
63.9 cm x 24.4 cm x 54 cm - with stand
6.72 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , MHL / HDMI , 4 x USB 3.0 , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
MTBF
70,000 hour(s)
31.77 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 24.4 cm - height: 54 cm - weight: 6.72 kg , Without stand - width: 63.9 cm - depth: 6.8 cm - height: 40.5 cm - weight: 4.4 kg
ENERGY STAR Certified
20 - 80%
BYPV C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.60
BYPV C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.97
BYPV C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.28
BYPV C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BYPV C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.34
Diagonal Size: 27in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: Mobile High-Definition Link (MHL)
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 300 - 500
