Product
Brand
Philips 272B4QPJCB/00 27" 2560x1440 DVI VGA Monitor
Quicklinx: BYPTWS00 Mfr#: 272B4QPJCB/00
Philips monitors are designed to bring out the best in everything you do. By combining the innovations with thoughtful design, these easy-to-use displays offer lasting performance, vivid imagery and timeless style.
Everyone wants to do their part to save the planet, but sometimes daily life gets in the way of your best intentions. Philips designs clever solutions that do the thinking for you. The PowerSensor is a smart monitor technology with a built-in "people-sensor." Infrared signals detect the presence of a person in front of the monitor and automatically reduce energy consumption by up to 80% the minute they walk away. So every meeting, coffee break, trip to the printer and chat with a coworker is an opportunity to reduce your carbon footprint and operating costs. Effortlessly.
Philips 272B4QPJCB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
65 kWh
Power Consumption (On mode)
45 W
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
63.9 cm x 24.4 cm x 54 cm
6.72 kg
Environmental Standards
ENERGY STAR Qualified
TCO Certified Edge, TCO Displays 6.0, EPA 6.0
Display Type
Energy Class
Class C
65 kWh
45 W
Diagonal Size
27"
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
SmartResponse, MultiView, SmartContrast
63.9 cm x 24.4 cm x 54 cm - with stand
6.72 kg
Audio
Speakers - internal
VGA , DVI , HDMI , DisplayPort , 4 x USB 3.0 , Audio line-in , Headphones
Mechanical
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable
Power Supply
Internal
31.77 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Philips SmartControl Premium
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 24.4 cm - height: 54 cm - weight: 6.72 kg , Without stand - width: 63.9 cm - depth: 6.8 cm - height: 40.5 cm
ENERGY STAR Certified
BYPT C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.79
BYPT C2G HDMI to DisplayPort Adapter Converter In Stock £35.86
BYPT C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.05
BYPT C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYPT C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £18.16
BYPT C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.15
BYPT C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £12.38
