Product
Philips 272B4QPJCB/00 27" 2560x1440 DVI VGA Monitor
Quicklinx: BYPTWS00 Mfr#: 272B4QPJCB/00
Philips monitors are designed to bring out the best in everything you do. By combining the innovations with thoughtful design, these easy-to-use displays offer lasting performance, vivid imagery and timeless style.
Everyone wants to do their part to save the planet, but sometimes daily life gets in the way of your best intentions. Philips designs clever solutions that do the thinking for you. The PowerSensor is a smart monitor technology with a built-in "people-sensor." Infrared signals detect the presence of a person in front of the monitor and automatically reduce energy consumption by up to 80% the minute they walk away. So every meeting, coffee break, trip to the printer and chat with a coworker is an opportunity to reduce your carbon footprint and operating costs. Effortlessly.
  • PLS Quad HD
    This professional Philips display uses latest PLS Quad HD panel giving you ultra-high-res brilliant wide angle images with 2560x1440 pixel resolution. With excellent 8 bit color depth combined with 109 ppi density, you can now enjoy professional true color sRGB images compared to limited 6 bit color depth displays with 82ppi density. Its higher brightness and lower power consumption relative to conventional wide view angle displays ensure you always have brilliant performance, while saving energy too. It's best suited for professional applications like CAD, Graphics design, Image rendering.
  • Crystalclear images
    These latest Philips screens deliver Crystalclear, Quad HD 2560x1440 or 2560x1080 pixel images. Utilizing high performance panels with high density pixel count, 178/178 wide viewing angles, enabled by high bandwidth sources like Displayport, HDMI, Dual link DVI or optional Thunderbolt, these displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystalclear images.
  • PowerSensor
    PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life.
  • Webcam
    Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel related costs.
  • MultiView technology
    With the ultra-high resolution Philips MultiView display you can now experience a world of connectivity in a comfortable way whether at office or at home. MultiView enables active dual connect and view so that you can work with multiple devices like PC and Notebook side-by-side simultaneously, making complex multi-tasking work a breeze. Watching live football feed from your set-top box on right side, while browsing the Internet from your notebook on the left is now easy. You may want to keep an eye on the live news feed with audio in the small window, while working on your latest blog.
  • Display Port with Daisy Chain
    This Philips display employs Display port 1.2a Multi Stream Transport (MST) technology with HBR2, which doubles the data throughput to 21.6 Gbps. This enables it to daisy chain multiple monitors, thereby increasing your efficiency dramatically. This daisy chain, multi-monitor capability makes this Philips display especially suitable for use in Finance, Banking, control room and other similar environment. To make use of this feature, your PC Graphics Card must be certified to DP1.2 with MST option.
  • SmartConnect
    With a plethora of connectivity, these Philips displays come equipped with multi connections like Dual link DVI, Display Port, universal HDMI connector, enabling you to enjoy high resolution uncompressed video and audio content. USB 3.0 option ensures that you can have super speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon!
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional.
  • USB 3.0 super speed
    Super Speed USB 3.0 deploys 5.0 gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard significantly reducing data transfer time saving you time and money. With more bandwidth, super speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use the large capacity storage devices. Sync-N-Go technology ensures you don't have to wait anymore for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backward compatible.
Philips 272B4QPJCB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
65 kWh
Power Consumption (On mode)
45 W
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
63.9 cm x 24.4 cm x 54 cm
6.72 kg
Environmental Standards
ENERGY STAR Qualified
TCO Certified Edge, TCO Displays 6.0, EPA 6.0
Display Type
Energy Class
Class C
65 kWh
45 W
Diagonal Size
27"
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
SmartResponse, MultiView, SmartContrast
63.9 cm x 24.4 cm x 54 cm - with stand
6.72 kg
Audio
Speakers - internal
VGA , DVI , HDMI , DisplayPort , 4 x USB 3.0 , Audio line-in , Headphones
Mechanical
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable
Power Supply
Internal
31.77 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Philips SmartControl Premium
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 24.4 cm - height: 54 cm - weight: 6.72 kg , Without stand - width: 63.9 cm - depth: 6.8 cm - height: 40.5 cm
ENERGY STAR Certified
BYPT C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.35
BYPT C2G HDMI to DisplayPort Adapter Converter In Stock £37.67
BYPT C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.77
BYPT C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.85
BYPT C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYPT C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.49
BYPT C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.31
BYPT C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.88
BYPT C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.00
