Product
Brand
Philips 271S4LPYEB/00 27" 1920x1080 DVI VGA Monitor
Quicklinx: BYQ4WS00 Mfr#: 271S4LPYEB/00
The Philips PowerSensor LED display using 25% recycled materials and PVC, BFR-free housing is ideal for eco-friendly productivity.
Philips S-line 271S4LPYEB - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured black with black stand
63.9 cm x 24.2 cm x 58 cm
7.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage, Smart Ergo base
63.9 cm x 24.2 cm x 58 cm - with stand
7.5 kg
VGA , DVI-D (HDCP) , DisplayPort
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
21.3 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 24.2 cm - height: 58 cm - weight: 7.5 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.1 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
BYQ4 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.85
BYQ4 C2G HDMI to DisplayPort Adapter Converter In Stock £35.86
BYQ4 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.05
BYQ4 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYQ4 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £18.16
BYQ4 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.15
BYQ4 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £12.38
