Philips 27" Full HD LED Monitor 1920 x 1080 16:9 Black Bezel
Quicklinx: 98Y5WS00 Mfr#: 273V5LHSB/00
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
£127.38 ex VAT
£152.85 inc VAT
Enjoy vivid LED pictures on this big Philips display, it is equipped with HDMI and SmartControl Lite, it is great choice!
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
  • Mercury Free
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • SmartContrast
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • 16:9 Full HD
    The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colours.
Philips V-line 273V5LHSB - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Textured black, black hairline
64.6 cm x 24 cm x 39.8 cm
4.53 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Display Type
Energy Class
Class B
48 kWh
33 W
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, SmartControl Lite
64.6 cm x 24 cm x 39.8 cm - with stand
4.53 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
23.14 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 64.6 cm - depth: 24 cm - height: 39.8 cm - weight: 4.53 kg , Without stand - width: 64.6 cm - depth: 5.7 cm - height: 48.2 cm - weight: 4 kg
TCO Certified
ENERGY STAR Certified
20 - 80%
98Y5 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
98Y5 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.29
98Y5 C2G 5m Select High Speed HDMI with Ethernet In Stock £25.74
98Y5 C2G 10m Select High Speed HDMI with Ethernet In Stock £40.75
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 100 - 150
