Philips 258B6QUEB  25" 2560x1440 5ms VGA DVI DP HDMI USB-C
Quicklinx: C9Z3WS00 Mfr#: 258B6QUEB/00
Diagonal Size: 25in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, USB-C + 1 more
Hurry, only 1 left in stock!
£279.41 ex VAT
£335.29 inc VAT
Express delivery Order within the next 18 hours for delivery on Wednesday
Simple USB-C connection and crystal-clear IPS images. The Philips B line monitor with USB-C connector allows simple notebook docking via one cable for fast data and video to a crystal-clear IPS display, and even notebook charging.
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • SmartImage pre-sets for easy optimised image settings
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • SmartErgoBase enables user-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • Crystal clear images with Quad HD 2560 x 1440 pixels
    These latest Philips screens deliver CrystalClear, Quad HD 2560x1440 or 2560x1080 pixel images. Utilising high-performance panels with a high-density pixel count, enabled by high-bandwidth sources like DisplayPort, HDMI, Dual link DVI, these new displays will make your images and graphics come alive. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you CrystalClear images.
  • IPS technology for full colours and wide viewing angles
    IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • Narrow border display for seamless appearance
    The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
  • All your connections through one USB-C cable
    The new USB 3.1 Type-C cable with a slim and reversible connector offers easy one-cable-docking. With USB 3.1 you get the fastest speeds, 20 times as fast as USB 2.0, allowing you to transfer a 4K movie in less than 60 seconds. Simplify by connecting all your peripherals to your monitor as a dock with one cable to the notebook, including high-resolution video output from your PC to your monitor. Additionally, USB-C even allows you to power and charge your notebook from the monitor, eliminating the need for extra power cables. All your connections through one simple cable.
Philips Brilliance B-line 258B6QUEB - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class B
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
37 W
USB 3.0 hub, Fast Ethernet network adapter
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, USB
Display Position Adjustments
Textured black with black stand
57.1 cm x 24.4 cm x 51.1 cm
7 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, CECP, cETLus, CU-EAC
3-year warranty
Display Type
Energy Class
Class B
54 kWh
37 W
Diagonal Size
25"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, SmartImage, Smart Ergo base, SmartControl Premium, SmartConnect, Flicker Free technology, BFR/PVC-free, Mercury free, USB 3.0 Fast Charge, USB-C Docking
57.1 cm x 24.4 cm x 51.1 cm - with stand
7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (dual link) (HDCP) , DisplayPort , Headphones , Audio line-in , 3 x USB 3.0 , HDMI (HDCP) , USB-C , Network (RJ-45)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB-C cable , 1 x USB-C to USB-A cable
MTBF
70,000 hour(s)
24.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Dimensions & Weight Details
With stand - width: 57.1 cm - depth: 24.4 cm - height: 51.1 cm - weight: 7 kg , Without stand - width: 57.1 cm - depth: 5.5 cm - height: 34.4 cm - weight: 4.66 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
20 - 80%
Philips 258B6QUEB  25 Bundle deal on Philips 258B6QUEB 25" 2560x1440 5ms VGA DVI DP HDMI USB-C
£378.58
Diagonal Size: 25in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: USB-C
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 150 - 300
