The Philips AH-IPS LED display using 65% post consumer recycled plastics and PVC, BFRfree is ideal for eco-friendly productivity.
Crystalclear images
These Philips screens deliver Crystalclear, Quad HD 2560x1440 or 2560x1080 pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like Displayport, HDMI, Dual link DVI, these stunning displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystalclear images. -
AH-IPS technology
This Philips display uses advanced AHIPS panels utilizing improved structure resulting in superior color reproduction, response time and power consumption compared to other wide view angle panels. Unlike standard TN panels, AH-IPS panels exhibit least amount of Gamma fluctuation and therefore are able to show consistent color even at 178/178 degrees and in pivot mode. With remarkable performance, it is best suited for applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing. -
Flicker-free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a great solution to regulate brightness and reduce flicker for more comfortable viewing. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button! -
Super Narrow Border
Utilizing this technology panels, these Philips displays are designed with minimalistic approach by limiting the outer bezel thickness to about 2.5 mm. Combined with in-panel black matrix strip of only 3.5 mm, the overall border dimensions are reduced significantly allowing for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setup like gaming, graphic design and professional applications, the ultra-narrow bezel display gives you the feeling of using one large display. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. -
Low bezel-to-table height
The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain. -
USB 3.0 super speed
Super Speed USB 3.0 deploys 5.0 Gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard significantly reducing data transfer time saving you time and money. With more bandwidth, super speed transfer rates, better power management and superior overall performance, USB 3.0 sets the global standard allowing you to use the large capacity storage devices. Sync-N-Go technology ensures you don't have to wait anymore for bandwidth to be freed up.
- Philips Brilliance B-line 258B6QJEB - LED monitor - 25"
- LED-backlit LCD monitor - 25"
- Energy Class
- Class B
- Energy Consumption per Year
- 54 kWh
- Power Consumption (On mode)
- 37 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.216 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey), 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black with black stand
- 57.1 cm x 24.4 cm x 51.1 cm
- 7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, CECP, EPA, cETLus, CU-EAC
- Display Type
- Energy Class
- Class B
- 54 kWh
- Diagonal Size
- 25"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.216 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, SmartContrast, SmartImage, Smart Ergo base, SmartControl Premium, SmartConnect, Flicker Free technology, Mercury free
- 57.1 cm x 24.4 cm x 51.1 cm - with stand
- 7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , DisplayPort , 2 x USB 2.0 , Headphones , Audio line-in , 2 x USB 3.0 , HDMI (HDCP)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 70,000 hour(s)
- Input Voltage
- 37 W
- Power Consumption (Typical)
- 24.6 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 57.1 cm - depth: 24.4 cm - height: 51.1 cm - weight: 7 kg , Without stand - width: 57.1 cm - depth: 5.5 cm - height: 34.4 cm - weight: 4.66 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
