Your basket is empty
Philips 258B6QJEB/00 25" 2560x1440 DVI VGA Monitor
Quicklinx: BYPSWS00 Mfr#: 258B6QJEB/00
The Philips AH-IPS LED display using 65% post consumer recycled plastics and PVC, BFRfree is ideal for eco-friendly productivity.
Philips Brilliance B-line 258B6QJEB - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class B
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
37 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured black with black stand
57.1 cm x 24.4 cm x 51.1 cm
7 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, CECP, EPA, TCO Displays 6.0, cETLus, CU-EAC
Display Type
Energy Class
Class B
54 kWh
37 W
Diagonal Size
25"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, SmartImage, Smart Ergo base, SmartControl Premium, SmartConnect, Flicker Free technology, Mercury free
57.1 cm x 24.4 cm x 51.1 cm - with stand
7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , DisplayPort , 2 x USB 2.0 , Headphones , Audio line-in , 2 x USB 3.0 , HDMI (HDCP)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
70,000 hour(s)
24.6 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
With stand - width: 57.1 cm - depth: 24.4 cm - height: 51.1 cm - weight: 7 kg , Without stand - width: 57.1 cm - depth: 5.5 cm - height: 34.4 cm - weight: 4.66 kg
ENERGY STAR Certified
20 - 80%
BYPS C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.42
BYPS C2G HDMI to DisplayPort Adapter Converter In Stock £33.52
BYPS C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £20.60
BYPS C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYPS C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £16.98
BYPS C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £15.10
BYPS C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £11.56
