Philips 247E6QDAD/00 24" 1920x1080 DVI VGA HDMI Monitor
Quicklinx: BYZ8WS00 Mfr#: 247E6QDAD/00
This brilliant IPS-ADS display offers stunning visuals wrapped in an elegance-inspired design for a light and fresh face in any home or office.
  • HDMI Ready
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • IPS-ADS technology
    IPS-ADS displays use an advanced technology that gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-ADS displays give you remarkably crisp images with vivid colours, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand colour accuracy and consistent brightness at all times.
  • 16:9 Full HD display
    The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colours.
  • SmartImage Lite
    SmartImage Lite is an exclusive, leading edge Philips technology that analyses the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, colour saturation and sharpness of images and videos for ultimate display performance- all in real time with the press of a single button.
  • SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • Modern Touch controls
    Touch controls are intelligent, touch-sensitive icons that replace protruding buttons to allow users to adjust the monitor to their requirements. Responding to the lightest touch, Touch control gives the monitor a modern feel.
Philips E-line 247E6QDAD - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
24 W
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 14 ms (typical)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
Glossy cherry black
56.1 cm x 21.2 cm x 42.9 cm
3.65 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, cETLus
Display Type
Energy Class
Class A
34 kWh
Diagonal Size
23.6"
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartImage Lite, SmartResponse, SmartContrast, WideView, TrueVision, 4:3 in Wide, Touch Control, Mercury free
Glossy cherry black
56.1 cm x 21.2 cm x 42.9 cm - with stand
3.65 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
VGA , HDMI , DVI-D , MHL , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
MTBF
50,000 hour(s)
Power Supply
External
Input Voltage
24 W
Power Consumption (Typical)
16.23 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / Windows 8
Dimensions & Weight Details
With stand - width: 56.1 cm - depth: 21.2 cm - height: 42.9 cm - weight: 3.65 kg , Without stand - width: 56.1 cm - depth: 4.3 cm - height: 34.7 cm - weight: 3.27 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
BYZ8 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
