The Philips LED display using PVC, BFR-free housing is ideal for eco-friendly productivity.
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
- Philips S-line 243S5LSB - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black, black hairline
- 55.1 cm x 22 cm x 42 cm
- 3.66 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV, BSMI, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, WEEE, cETLus, RCM, ISO9241-307
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Sync on Green, sRGB colour management, HDCP, SmartContrast, Mercury free
- 55.1 cm x 22 cm x 42 cm - with stand
- 3.66 kg
- VGA , DVI-D (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- MTBF
- 30,000 hour(s)
- Input Voltage
- Power Consumption (Typical)
- 16.7 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 55.1 cm - depth: 22 cm - height: 42 cm - weight: 3.66 kg , Without stand - width: 55.1 cm - depth: 5.2 cm - height: 34.4 cm - weight: 3.22 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
