Philips 243S5LJMB 24" 1920x1080 1ms DVI HDMI LED Monitor
Quicklinx: F72LWS00 Mfr#: 243S5LJMB/00
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
34 in stock
£109.47 ex VAT
£131.36 inc VAT
The Philips LED display using PVC, BFR-free housing is ideal for eco-friendly productivity.
  • Built-in stereo speakers
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • HDMI Ready
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • 16:9 Full HD display
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
  • Mercury Free
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • SmartContrast
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • DisplayPort connection
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates- making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
Philips S-line 243S5LJMB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.272 mm
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Black with hairline texture
56 cm x 23.2 cm x 52 cm
5.3 kg
Environmental Standards
TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
FCC Class B certified, TUV, BSMI, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, cETLus, RCM, Ukraine
Display Type
Energy Class
Class A
32 kWh
22 W
Diagonal Size
24"
Viewable Size
23.6"
Built-in Devices
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, SmartResponse, Mercury free
56 cm x 23.2 cm x 52 cm - with stand
5.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Audio line-in , Headphones , DVI-D , 4 x USB 2.0
Mechanical
Tilt Angle
-5/20
Swivel Angle
175
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
VGA cable , HDMI cable , Audio cable
MTBF
70000 hour(s)
Security Slot Type
Kensington security slot
AC 120/230 V (50 - 60 Hz)
15.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 56 cm - depth: 23.2 cm - height: 52 cm - weight: 5.3 kg , Without stand - width: 56 cm - depth: 5.3 cm - height: 34.8 cm - weight: 3.35 kg
Shipping Width
62 cm
Shipping Depth
19.1 cm
Shipping Height
52 cm
Shipping Weight
8.1 kg
TCO Certified
ENERGY STAR Certified
20 - 80%
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 100 - 150
