Product
Philips 241P6VPJKEB/00 24" 3840x2160 VGA DVI 4K HDMI Monitor
Quicklinx: BYMLWS00 Mfr#: 241P6VPJKEB/00
This advanced Philips display utilizes high performance panels to deliver UltraClear, 4K Ultra HD (3840 x 2160) resolution images. Whether you are demanding professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets, Philips display will make your images and graphics come alive.
  • AH-IPS technology
    This advanced Philips display uses AH-IPS panels resulting in superior color reproduction, response time and power consumption. AH-IPS panels show consistent color even at wide angles and in pivot mode. With remarkable performance, AH-IPS is optimally suited for applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing.
  • Deep colors
    The 10-bit display delivers rich color depth with billion colors and internal processing for re-creating smooth, natural colors without gradations and color banding.
  • Full sRGB color
    Experience vivid, and true-to-life colors. With coverage of sRGB color standard, you can have confidence the colors you see on the display are accurate and true-to-life.
  • Flicker-free technology
    Philips Flicker-free technology applies an improved solution to regulate brightness and reduce flicker for more comfortable viewing.
  • MultiView technology
    With the ultra high resolution Philips MultiView display you can now experience a world of connectivity in a comfortable way whether at office or at home. MultiView enables active dual connect and view so that you can work with multiple devices like PC and notebook side-by-side simultaneously, making complex multi-tasking work a breeze. Watching live football feed from your set-top box on right side, while browsing the Internet from your notebook on the left is now easy. You may want to keep an eye on the live news feed with audio in the small window, while working on your blog.
  • Smart Ergo base
    The Smart Ergo base is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional.
  • PowerSensor
    PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs and prolonging monitor life.
  • Webcam
    Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel related costs.
Philips Brilliance P-line 241P6VPJKEB - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
63 kWh
Power Consumption (On mode)
43 W
Microphone, 2.0 megapixel camera, USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.137 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments
Textured black
53.1 cm x 25.6 cm x 42.2 cm
5.85 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, TCO Certified Edge, E-Standby, KC, CECP, EPA, TCO Displays, cETLus, RCM, Ukrain Safety, CU-EAC
Display Type
Energy Class
Class C
63 kWh
43 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.137 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture in picture, ambient light sensor, Sync on Green, PowerSensor, SmartResponse, MultiView, SmartImage, Smart Ergo base, 99% sRGB colour gamut, Flicker Free technology, BFR/PVC-free, Mercury free, PBP
Textured black
53.1 cm x 25.6 cm x 42.2 cm - with stand
5.85 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI-D (HDCP) , VGA , MHL / HDMI , 3 x USB 3.0 , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
70,000 hour(s)
30.11 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 53.1 cm - depth: 25.6 cm - height: 42.2 cm - weight: 5.85 kg , Without stand - width: 53.1 cm - depth: 5.2 cm - height: 36.3 cm - weight: 3.36 kg
ENERGY STAR Certified
20 - 80%
BYML C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.23
BYML C2G HDMI to DisplayPort Adapter Converter In Stock £37.08
BYML C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.43
BYML C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.11
BYML C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.05
BYML C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.54
BYML C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.74
