The Philips PowerSensor AH-IPS LED display with Webcam helps you collaborate and communicate, saving you time and money.
AH-IPS technology
This latest Philips display uses advanced AH-IPS panels utilizing improved structure resulting in superior color reproduction, response time and power consumption compared to other wide view angle panels. Unlike standard TN panels, AH-IPS panels exhibit least amount of Gamma fluctuation and therefore are able to show consistent color even at 178/178 degrees and in pivot mode. With remarkable performance, it is best suited for applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing. -
Flicker-free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips flicker-free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like office, photo, movie, game, economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button! -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. -
Built-in stereo speakers
A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc. depending on model and design. Webcam Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel related costs. -
USB hub
Super Speed USB 3.0 deploys 5.0 gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard significantly reducing data transfer time saving you time and money. With more bandwidth, super speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use the large capacity storage devices. Sync-N-Go technology ensures you don't have to wait anymore for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backward compatible. -
MHL technology
Mobile High Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way. -
LightSensor
Light Sensor uses a sensor to adjust the picture brightness depending on the room ambient light conditions for an optimized picture.
- Philips Brilliance P-line 241P6QPJKES - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 24 W
- Microphone, camera, USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 14 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Internal
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black, textured silver
- 53.1 cm x 25.6 cm x 42.2 cm
- 6.47 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CCC, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, E-Standby, KC, CECP, cETLus, CU-EAC
- Display Type
- Energy Class
- Class A
- 35 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, HDCP, Eco-Mode, PowerSensor, SmartResponse, SmartContrast, SmartImage, game mode, Cinema Mode, Mobile High-Definition Link (MHL), Smart Ergo base, SmartConnect, Flicker Safe, Mercury free
- 53.1 cm x 25.6 cm x 42.2 cm - with stand
- 6.47 kg
Audio
- Speakers - stereo - internal
- Output Power / Channel
- 2 Watt
- VGA , DVI-D (HDCP) , HDMI , DisplayPort , 3 x USB 3.0 , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- 24 W
- Power Consumption (Typical)
- 18.27 Watt
- Power Consumption Stand by
- 0.3 Watt
- On / Off Switch
- Included Software
- Philips SmartControl Premium
- Dimensions & Weight Details
- With stand - width: 53.1 cm - depth: 25.6 cm - height: 42.2 cm - weight: 6.47 kg , Without stand - width: 53.1 cm - depth: 5.2 cm - height: 36.3 cm - weight: 3.98 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
