Philips monitors are designed to bring out the best in everything you do. By
combining the innovations with thoughtful design, these easy-to-use displays offer lasting performance, vivid imagery and timeless style.
Reveal the finest details
With great resolution, UltraClear HD delivers four times the precision of Full HD. This monitor offers the ultimate combination of size, picture clarity and performance. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like DisplayPort, HDMI, Dual link DVI, these displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets. -
The clearest way to get things done
This professional Philips display uses latest PLS Quad HD panel giving you ultra high-res brilliant wide angle images with great pixel resolution. With excellent 8 bit color depth combined with 109 ppi density, you can now enjoy professional true color sRGB images compared to limited 6 bit color depth displays with 82ppi density. Its higher brightness and lower power consumption relative to conventional wide view angle displays ensure youalways have brilliant performance, while saving energy too. It’s best suited for professional applications like CAD, Graphics design, Image rendering etc. -
See the perfect color
The perfect color, you know it when you see it. These monitors feature high quality brilliant panels for rich accurate color from every angle. Know that your color is consistent with professional industry-standard color, 99% Adobe RGB and 100% sRGB. Out of the box color precision with factory color calibration and a factory calibration report give you confidence right from the start. Adjust the color to your exact standards with six axis custom color adjustment. Save time and money with Philips monitors with PerfectKolor technology. -
Level of productivity
UltraWide Philips screens are designed with multi-tasking in mind. Connect and view two different sources at the same time with advanced Multiview technology. HDMI, DVI and DisplayPort connections let you access almost any device while USB 3.0 provides superspeed data transfer. Images look sharper than ever in ultra-high resolution and the IPS panel delivers distortion-free viewing from any angle. The slim, elegant design features an Ultra Narrow Bezel to further maximize your viewing area. No matter what you need to accomplish, this display takes productivity to the extreme. -
Automatically reduce energy consumption by up to 80%
Everyone wants to do their part to save the planet, but sometimes daily life gets in the way of your best intentions. Philips designs clever solutions that do the thinking for you. The PowerSensor is a smart monitor technology with a built-in “people-sensor.” Infrared signals detect the presence of a person in front of the monitor and automatically reduce energy consumption by up to 80% the minute they walk away. So every meeting, coffee break, trip to the printer and chat with a coworker is an opportunity to reduce your carbon footprint and operating costs. Effortlessly.
- Philips 241P6QPJES - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Input Connectors
- HDMI, DVI, DisplayPort, VGA
- Speakers
- Internal
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Silver
- 53.1 cm x 25.6 cm x 42.2 cm
- 6.47 kg
- Environmental Standards
- ENERGY STAR Qualified
- EPA 6.0
- Display Type
- Energy Class
- Class A
- Diagonal Size
- 23.8"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- PowerSensor, SmartResponse, SmartContrast, SmartPower
- Silver
- 53.1 cm x 25.6 cm x 42.2 cm - with stand
- 6.47 kg
Audio
- Speakers - internal
- VGA , DVI , HDMI , DisplayPort , 4 x USB 3.0 , Headphones , Audio line-in
Mechanical
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable
- EPA 6.0
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 18.27 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- Philips SmartControl Premium
- Dimensions & Weight Details
- With stand - width: 53.1 cm - depth: 25.6 cm - height: 42.2 cm - weight: 6.47 kg , Without stand - width: 53.1 cm - depth: 5.2 cm - height: 36.3 cm
Sustainability Information
- ENERGY STAR Certified
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £15.80 |
