Philips 241B8QJEB 24" 1920x1080 5ms DVI HDMI LED Monitor
Quicklinx: F72GWS00 Mfr#: 241B8QJEB/00
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort, VGA (HD-15), DVI
More than 50 In Stock
£130.52 ex VAT
£156.62 inc VAT
Get your best work done with the Philips 24" Full HD monitor. Crisp and vivid Full HD gives you the space and clarity to see your work. Features like height-adjustment, Flicker-free and LowBlue mode make work easy on the eyes.
  • IPS technology for full colours and wide viewing angles
    IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • 16:9 Full HD display for crisp, detailed images
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
  • SmartImage pre-sets for easy optimised image settings
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • LowBlue Mode for easy-on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • SmartErgoBase enables user-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • USB 3.0 enables fast data transfers and smart phone charging
    Super Speed USB 3.0 deploys a 5.0 Gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the global standard, allowing you to use large-capacity storage devices. Sync-N-Go technology ensures that you no longer have to wait for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backwards compatible.
  • SmartConnect with DisplayPort, HDMI and VGA connections
    With a plethora of connectivity, these Philips displays come equipped with multiple connections like VGA, Display Port and universal HDMI connector, enabling you to enjoy high-resolution uncompressed video and audio content. USB connections ensure that you can have super-speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon!
  • Designed to meet environmental standards
    Designed for sustainability and reduced operating costs, this monitor meets environmental standards. Such as: ENERGY STAR, EPEAT, TCO Certified.
Philips B Line 241B8QJEB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
14 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
103.8% sRGB, 89.9% NTSC
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Black texture
54 cm x 20.6 cm x 50.8 cm
4.97 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SEMKO, CB, TUV Ergo, PSB, DDC/CI, RoHS, WEEE, PSE Mark, MEPS, J-MOSS, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2
3-year warranty
Display Type
Energy Class
Class D
26 kWh
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 76 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Sync on Green, SmartImage, SmartConnect, Low Blue Light Mode, Flicker Free technology, Adaptive-Sync technology, EasyRead
Black texture
54 cm x 20.6 cm x 50.8 cm - with stand
4.97 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort , HDMI , USB 3.0 (fast charging) , USB 3.0 , 2 x USB 2.0 , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
350
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
14 W
14 kWh/1000h
Power Consumption (Typical)
13 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Dimensions & Weight Details
With stand - width: 54 cm - depth: 20.6 cm - height: 50.8 cm - weight: 4.97 kg , Without stand - width: 54 cm - depth: 5 cm - height: 32.3 cm - weight: 3.37 kg
Shipping Width
60 cm
Shipping Depth
19.8 cm
Shipping Height
46.8 cm
Shipping Weight
7.17 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - 3 years
20 - 80%
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: VGA (HD-15)
Interfaces: DVI
Brand: Philips
