Philips 241B6QPYEB/00 24" 1920x1080 DVI VGA Monitor
Quicklinx: BYPRWS00 Mfr#: 241B6QPYEB/00
The Philips PowerSensor AH-IPS LED display, which uses 65% post-consumer recycled plastics and PVC, BFR-free housing, is ideal for eco-friendly productivity.
  • AH-IPS technology
    This latest Philips display uses advanced AH-IPS panels utilizing improved structure resulting in superior color reproduction, response time and power consumption compared to other wide view angle panels. Unlike standard TN panels, AH-IPS panels exhibit the smallest amount of Gamma fluctuation and therefore are able to show consistent color even at 178/178 degrees and in pivot mode. With a remarkable performance, it is best suited to applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing.
  • Flicker-Free technology
    Because of the way brightness is controlled on LED-backlit screens, some users experience flicker on the screen, which causes eye fatigue. Philips Flicker-Free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and optimizes your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • Low bezel-to-table height
    Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
  • Built-in stereo speakers
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
Philips Brilliance B-line 241B6QPYEB - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
Textured black with black stand
53.1 cm x 25.6 cm x 42.2 cm
6.47 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, cETLus
Display Type
Diagonal Size
23.8"
Built-in Devices
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage, WideView, Smart Ergo base, SmartControl Premium, Flicker Free technology, Mercury free
53.1 cm x 25.6 cm x 42.2 cm - with stand
6.47 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort , 4 x USB 2.0 , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
16.73 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
With stand - width: 53.1 cm - depth: 25.6 cm - height: 42.2 cm - weight: 6.47 kg , Without stand - width: 53.1 cm - depth: 5.2 cm - height: 36.3 cm - weight: 3.98 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
BYPR C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
