Philips 240V5QDAB/00 24" 1920x1080 DVI VGA HDMI Monitor
While Stocks Last! Was £91.91, Now £84.00 ex VAT
Last Few Remaining
Quicklinx: BYZHWS00 Mfr#: 240V5QDAB/00
Enjoy vibrant pictures on this Philips display. Equipped with HDMI and stereo speakers, it’s a great choice!
  • IPS-ADS technology
    IPS-ADS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-ADS displays give you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
  • 16:9 Full HD display
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colors expect a true to life picture.
  • SmartContrast
    SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for amazing digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • HDMI ready
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. A HDMI cable enables high-quality digital video and audio all transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • Built-in stereo speakers
    You can enjoy all your multimedia and social applications with stereo sound. These built-in speakers not only sound great, but also helps you to get rid of external wire clutter and save valuable desktop space.
  • Mercury-free
    Philips monitors with LED backlighting are free of Mercury content, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its life cycle, from manufacturing to disposal.
Philips V-line 240V5QDAB - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Textured black, black hairline
55.3 cm x 21.9 cm x 42 cm
4.09 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, C-Tick, BSMI, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, EPA, TCO Displays, cETLus
Display Type
Energy Class
Class B
38 kWh
26 W
Diagonal Size
23.8"
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, SmartControl Lite, Mercury free
55.3 cm x 21.9 cm x 42 cm - with stand
4.09 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI (HDCP) , DVI-D (HDCP) , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
19.23 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7, Windows 8.1
Dimensions & Weight Details
With stand - width: 55.3 cm - depth: 21.9 cm - height: 42 cm - weight: 4.09 kg , Without stand - width: 55.3 cm - depth: 5.5 cm - height: 34.3 cm - weight: 3.69 kg
ENERGY STAR Certified
20 - 80%
BYZH C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.15
BYZH C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.54
BYZH C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.31
BYZH C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BYZH C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.66
BYZH C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £39.91
BYZH C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.85
BYZH C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £53.76
