Your basket is empty
Philips 240S4QMB/00 24" 1920x1200 DVI VGA Monitor
Quicklinx: BYQ2WS00 Mfr#: 240S4QMB/00
The Philips ergonomic LED display using recycled materials and PVC, BFR free housing is ideal for eco-friendly productivity.
Philips S-line 240S4QMB - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23.6 W
Stereo speakers
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Black texture
55.5 cm x 22.7 cm x 54.3 cm
6.34 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 6.0, cETLus
3 years warranty
Display Type
Energy Class
Class A
34 kWh
23.6 W
Diagonal Size
24"
Built-in Devices
Stereo speakers
Panel Type
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartContrast, SmartImage, SmartPower, Smart Ergo base, BFR/PVC-free, Mercury free
Black texture
55.5 cm x 22.7 cm x 54.3 cm - with stand
6.34 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
40,000 hour(s)
Power Supply
Internal
23.59 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 55.5 cm - depth: 22.7 cm - height: 54.3 cm - weight: 6.34 kg , Without stand - width: 55.5 cm - depth: 6.5 cm - height: 38.8 cm - weight: 4.48 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
BYQ2 C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £6.63
BYQ2 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.42
BYQ2 C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £8.29
BYQ2 C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BYQ2 C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.11
BYQ2 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £7.03
BYQ2 C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £47.00
