Enjoy this Philips PowerSensor display, using post-consumer recycled plastics and PVC, that features BFR-free housing and is ideal for eco-friendly productivity.
PowerSensor saves up to 80% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life -
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
SmartImage pre-sets for easy optimised image settings
SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button! -
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
USB 3.0 enables fast data transfers and smart phone charging
Super-Speed USB 3.0 deploys a 5.0 gbit/s transfer rate, which is about 10 times faster than the USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use large-capacity storage devices. Sync-N-Go technology ensures you don't have to wait for bandwidth to be freed up any more. Your investment in USB 2.0 devices is protected as it is backwards-compatible. -
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Narrow-border display for a seamless appearance
The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
- Philips Brilliance B-line 240B7QPJEB - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 26 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (SmartResponse)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Textured black
- 53.3 cm x 25.7 cm x 51.4 cm
- 6.37 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TUV GM, EPA, cETLus, CU-EAC
- Display Type
- Energy Class
- Class A
- 38 kWh
- 26 W
- Diagonal Size
- 24"
- Viewable Size
- 24.1"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- sRGB colour management, PowerSensor, SmartResponse, SmartImage, edge-to-edge glass, Smart Ergo base, SmartConnect, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Ultra Narrow Border, Mercury free, USB 3.0 Fast Charge, Wide Viewing Angle, Sync-N-Go
- Textured black
- 53.3 cm x 25.7 cm x 51.4 cm - with stand
- 6.37 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DisplayPort , Headphones , Audio line-in , 2 x USB 3.0 , HDMI
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable
- MTBF
- 70,000 hour(s)
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.3 Watt
- On / Off Switch
- Included Software
- Philips SmartControl
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- With stand - width: 53.3 cm - depth: 25.7 cm - height: 51.4 cm - weight: 6.37 kg , Without stand - width: 53.3 cm - depth: 5.7 cm - height: 36 cm - weight: 4.07 kg
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £96.99 | in stock |
£271.98
