Philips 240B4QPYEB/00 24" 1920x1200 DVI VGA Monitor
Quicklinx: BYPPWS00 Mfr#: 240B4QPYEB/00
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 15ms, 15ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£187.61 ex VAT
£225.13 inc VAT
The Philips PowerSensor LED display using recycled materials and PVC, BFR-free housing is ideal for eco-friendly productivity.
  • PowerSensor
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life
  • Zero power consumption
    At the flick of the 0 watt hard switch, which is conveniently located at the back of the monitor, you can completely cut off your monitor from AC power. This results in zero power consumption, reducing your carbon footprint even further
  • Built-in stereo speakers
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • Low bezel-to-table height
    Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • 2 Ports USB 2.0 HUB
    USB Hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, Web camera, PDA, Printer and many other devices which have USB connection available. The conveniently located USB 2.0 Hub on the monitor allows USB 2.0 signals to pass through to the computer. Note that many devices like cameras and HDD may need to be powered On independently, as they have higher power requirements than the monitor USB Hub can provide.
  • IPS technology
    IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
Philips Brilliance B-line 240B4QPYEB - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
22.3 W
USB Hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
55.5 cm x 24.4 cm x 55 cm
6.9 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, cETLus
Display Type
Energy Class
Class A
33 kWh
22.3 W
Diagonal Size
24"
Built-in Devices
USB Hub
Panel Type
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage, WideView, Smart Ergo base, SmartControl Premium, Mercury free, Zero power switch
55.5 cm x 24.4 cm x 55 cm - with stand
6.9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , DisplayPort , Headphones , Audio line-in , 2 x USB 2.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
MTBF
40,000 hour(s)
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
22.3 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 55.5 cm - depth: 24.4 cm - height: 55 cm - weight: 6.9 kg , Without stand - width: 55.5 cm - depth: 6.5 cm - height: 38.8 cm - weight: 4.57 kg
TCO Certified
ENERGY STAR Certified
20 - 80%
BYPP C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £10.91
BYPP C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.20
BYPP C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYPP C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £22.89
BYPP C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £15.89
Diagonal Size: 24in
Response Time: 15ms
Response Time: 15ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 150 - 300
