Philips 24" LED 1920 x 1080 HD Monitor 16:9 1000:1 Vesa Black Bezel
HDMI AND STEREO SPEAKERS!
Quicklinx: 98Y4WS00 Mfr#: 243V5LHAB/00
Diagonal Size: 23.6in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£98.24 ex VAT
£117.88 inc VAT
Enjoy vivid LED pictures on this Philips display. Equipped with HDMI and stereo speakers, it's a great choice!
  • Built-in stereo speakers
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • 16:9 Full HD display
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
  • HDMI Ready
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • Mercury Free
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • SmartContrast
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
Philips V-line 243V5LHAB - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
27 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (typical); 1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Textured black, black hairline
55.1 cm x 22 cm x 42 cm
3.66 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Display Type
Energy Class
Class B
40 kWh
27 W
Diagonal Size
23.6"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartContrast
55.1 cm x 22 cm x 42 cm - with stand
3.66 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI , DVI-D , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
19.18 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Included Software
Philips SmartControl Lite
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 55.1 cm - depth: 22 cm - height: 42 cm - weight: 3.66 kg , Without stand - width: 55.1 cm - depth: 5.2 cm - height: 34.4 cm - weight: 3.22 kg
TCO Certified
ENERGY STAR Certified
20 - 80%
Philips 24 Bundle deal on Philips 24" LED 1920 x 1080 HD Monitor 16:9 1000:1 Vesa Black Bezel
£197.41
Accessories (6)
98Y4 StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £65.12
98Y4 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £112.28
98Y4 StarTech.com Articulating Monitor Arm In Stock £104.51
98Y4 StarTech.com Dual Monitor Stand In Stock £70.92
98Y4 StarTech.com Cubicle Monitor Hanger In Stock £46.01
98Y4 StarTech.com Monitor Arm - Heavy Duty In Stock £74.67
Other bundles (5)
98Y4 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
98Y4 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.68
98Y4 C2G 5m Select High Speed HDMI with Ethernet In Stock £21.95
98Y4 C2G 10m Select High Speed HDMI with Ethernet In Stock £42.14
98Y4 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 50 - 100
