Enjoy vivid LED pictures on this Philips display. Equipped with HDMI and stereo speakers, it's a great choice!
Built-in stereo speakers
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
16:9 Full HD display
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture. -
HDMI Ready
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras). -
Mercury Free
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal. -
SmartControl Lite
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse. -
SmartContrast
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
- Philips V-line 243V5LHAB - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Class
- Class B
- Energy Consumption per Year
- 40 kWh
- Power Consumption (On mode)
- 27 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (typical); 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Textured black, black hairline
- 55.1 cm x 22 cm x 42 cm
- 3.66 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 40 kWh
- 27 W
- Diagonal Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, HDCP, SmartContrast
- 55.1 cm x 22 cm x 42 cm - with stand
- 3.66 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , HDMI , DVI-D , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 19.18 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Philips SmartControl Lite
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 55.1 cm - depth: 22 cm - height: 42 cm - weight: 3.66 kg , Without stand - width: 55.1 cm - depth: 5.2 cm - height: 34.4 cm - weight: 3.22 kg
- ENERGY STAR Certified
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 80%
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£173.60
Accessories (7)
StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount | In Stock | £64.11 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £109.46 |
StarTech.com Articulating Monitor Arm | In Stock | £101.86 |
StarTech.com Dual Monitor Stand | In Stock | £69.36 |
StarTech.com Cubicle Monitor Hanger | In Stock | £45.29 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £50.91 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £72.79 |
Other bundles (6)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 0.5m Select High Speed HDMI with Ethernet | In Stock | £6.31 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £21.05 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £40.43 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £54.75 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
