Philips 24" LCD Monitor with SmartControl Lite
ENJOY GREAT LED PICTURES IN VIVID COLOURS
Quicklinx: 8MBGWS00 Mfr#: 246V5LSB/00
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: [N/A]
Interfaces: DVI, VGA (HD-15)
£101.86 ex VAT
£122.23 inc VAT
Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with SmartControl lite, it's a great choice!
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
  • SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • SmartContrast
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • Mercury Free
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • 16:9 Full HD display
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
Philips V-line 246V5LSB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Textured black, glossy black
56.5 cm x 23.8 cm x 43.5 cm
4.65 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Display Type
Diagonal Size
24"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, sRGB colour management, HDCP, SmartContrast, 4:3 in Wide
56.5 cm x 23.8 cm x 43.5 cm - with stand
4.65 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
20.12 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Philips SmartControl Lite
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 56.5 cm - depth: 23.8 cm - height: 43.5 cm - weight: 4.65 kg , Without stand - width: 56.5 cm - depth: 6.3 cm - height: 35.4 cm - weight: 4.22 kg
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
20 - 80%
8MBG C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.55
8MBG C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.83
8MBG C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
8MBG C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.34
Diagonal Size: 24in
Response Time: 5ms
Speakers: [N/A]
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 100 - 150
