Philips 24" Brilliance LED Backlight LCD Full HD Monitor Black
Quicklinx: 8LRJWS00 Mfr#: 241B4LPYCB/00
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£138.94 ex VAT
£166.72 inc VAT
The Philips PowerSensor LED display using 65% post consumer recycled plastics and PVC, BFR free housing is ideal for Eco-friendly productivity.
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for Eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
  • LED technology ensures natural colours
    White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
  • PowerSensor saves up to 80% energy costs
    PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life
  • Zero power consumption with 0 watt hard switch
    At the flick of the 0 watt hard switch, which is conveniently located at the back of the monitor, you can completely cut off your monitor from AC power. This results in zero power consumption, reducing your carbon footprint even further
  • 65% post-consumer recycled plastics with TCO Edge
    TCO Edge certification is given to products that go beyond existing eco-labelling programmes. Over and above standard TCO requirements, it further mandates that the product uses a minimum of 65% post-consumer recycled plastics, is energy efficient, uses minimal hazardous materials, has 100% recyclable packaging and, amongst other requirements, is designed for easy recycling. You can rest assured that this Philips monitor is a cutting edge technology product, which is best in class ICT, benefitting you and the planet while helping you make a responsible green IT purchase!
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • Low bezel-to-table height for maximum reading comfort
    Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
  • SmartImage pre-sets for easy optimised image settings
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • DisplayPort offers audio and video over a single, long cable
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • SmartErgoBase enables user-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • USB Hub with 2 ports for easy connections
    USB Hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, Web camera, PDA, Printer and many other devices which have USB connection available. The conveniently located USB 2.0 Hub on the monitor allows USB 2.0 signals to pass through to the computer. Note that many devices like cameras and HDD may need to be powered On independently, as they have higher power requirements than the monitor USB Hub can provide.
Philips Brilliance B-line 241B4LPYCB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
3-year warranty
Display Type
Diagonal Size
24"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , Audio line-in/out , 2 x USB 2.0 , DisplayPort , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
21.44 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Dimensions & Weight Details
With stand - width: 56.5 cm - depth: 22.7 cm - height: 40.3 cm - weight: 6.3 kg , Without stand - width: 56.5 cm - depth: 5.5 cm - height: 35.2 cm - weight: 4.3 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Philips 24 Bundle deal on Philips 24" Brilliance LED Backlight LCD Full HD Monitor Black
£238.11
8LRJ C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £25.25
8LRJ C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
8LRJ C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.86
8LRJ C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.57
8LRJ C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.22
8LRJ C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.26
Diagonal Size: 24in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 100 - 150
