Philips 24" Black LCD Monitor Full HD Speakers VGA / DVI and HD
Quicklinx: DFQ9WS00 Mfr#: 243V7QDAB/00
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£80.02 ex VAT
£96.02 inc VAT
A perfect all-round display with stunning images that stretch from edge to edge, made easy on the eyes, in a compact, slim design.
  • Built-in speakers for audio without desktop clutter
    A pair of stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing etc, depending on model and design.
  • HDMI-ready for Full HD entertainment
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • SmartImage pre-sets for easy optimised image settings
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • SmartContrast for rich black details
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • IPS LED wide view technology for image and colour accuracy
    IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • 16:9 Full HD display for crisp, detailed images
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
  • LowBlue Mode for easy-on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Narrow-border display for a seamless appearance
    The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
Philips V-line 243V7QDAB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Textured black
54 cm x 20.9 cm x 41.5 cm
3.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, ICES-003, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, TCO Displays, cETLus, RCM, CU
Display Type
Energy Class
Class A
31 kWh
21 W
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartResponse, SmartContrast, SmartImage, edge-to-edge glass, Low Blue Light Mode, Flicker Free technology, Ultra Narrow Border, Mercury free, Wide Viewing Angle, EasyRead
Textured black
54 cm x 20.9 cm x 41.5 cm - with stand
3.5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI (HDCP) , DVI-D (HDCP) , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
MTBF
50,000 hour(s)
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 54 cm - depth: 20.9 cm - height: 41.5 cm - weight: 3.5 kg , Without stand - width: 54 cm - depth: 4.5 cm - height: 32.5 cm - weight: 3.1 kg
ENERGY STAR Certified
20 - 80%
Philips 24" Black LCD Monitor Full HD Speakers VGA / DVI and HD Bundle deal on Philips 24" Black LCD Monitor Full HD Speakers VGA / DVI and HD
£179.78
Diagonal Size: 24in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 50 - 100
