Philips 231P4QPYKEB/00 23" 1920x1080 VGA DVI Monitor
Quicklinx: BYM7WS00 Mfr#: 231P4QPYKEB/00
The Philips IPS LED display with webcam helps you collaborate and communicate, saving you time and money.
  • PowerSensor
    PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life.
  • IPS technology
    IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in 90-degree pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
  • Webcam
    Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel related costs.
  • DisplayPort
    DisplayPort is a digital link from PC to monitor without any conversion. With this high performance and zero latency, you get the fastest imaging and refresh rates - making DisplayPort the best choice for not only general office or home use, but also for the demanding gaming and movies, video editing and more. It also keeps interoperability in mind via use of various adapters.
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional.
  • 3 ports USB 2.0 hub
    USB hub allows user to conveniently connect their Plug and Play multimedia devices such as USB memory devices, camera, portable HDD, web camera, PDA, printer and many other devices which has USB connection available. The conveniently located USB 2.0 hub on the monitor allows USB 2.0 signals to pass thru to the computer.
  • Low bezel-to-table height
    The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain.
  • Zero power consumption
    At the flick of the 0 watt hard switch which is conveniently located at the back, you can completely cut-off your monitor from AC power. This results in zero power consumption reducing your carbon footprint even further.
Philips Brilliance P-line 231P4QPYKEB - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB Hub, 2.0 megapixel camera
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
Textured black with black stand
54.7 cm x 22 cm x 51.5 cm
5.23 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
Display Type
Diagonal Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartResponse, SmartContrast, SmartImage, Smart Ergo base
54.7 cm x 22 cm x 51.5 cm - with stand
5.23 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , DisplayPort , 3 x USB 2.0 , Headphones , Audio line-in , Microphone
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
29.1 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows Vista / XP / 7
Dimensions & Weight Details
With stand - width: 54.7 cm - depth: 22 cm - height: 51.5 cm - weight: 5.23 kg , Without stand - width: 54.7 cm - depth: 6 cm - height: 34.3 cm - weight: 3.09 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
BYM7 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
