Your basket is empty
Philips 23" S231C4AFD 1920x1080 14ms Smart All-in-One Monitor Android 4.2
Quicklinx: 98YCWS00 Mfr#: S231C4AFD/00
  • Android 4.2 (Jelly Bean)
  • Tegra 3
  • IEEE 802.11n
Open up a new world of opportunities with the Philips Smart All-in-One powered by Android. The expansive 23-inch multi-touch display is perfect for streaming HD videos, music, e-Learning and web surfing to the next level.
Philips Smart All-in-one S231C4AFD - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23" - touchscreen
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Microphone, USB Hub, 1.0 megapixel camera, 802.11b/g/n network adapter, SDHC card reader
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Glossy cherry black
56.3 cm x 7.7 cm x 39.3 cm
5 kg
Plug and Play, FCC Class B certified, CCC, DDC/CI, RoHS, Lead-Free, WEEE, CECP, CEL, cETLus
Display Type
Energy Class
Class B
38 kWh
26 W
Diagonal Size
23"
Operating System
Android 4.2
Configuration
Quad core nVidia Tegra T33 1.6GHz, 2GB DDR3, 8GB EMMC Flash
Supported Multimedia Formats
MPEG-4, H.264, MP3, JPEG, MPEG-2, OGG, AAC
USB flash drive up to 64GB
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
SmartImage, Android 4.2, Mercury free
Glossy cherry black
56.3 cm x 7.7 cm x 39.3 cm - with stand
5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Microphone - touchscreen
VGA (HD-15) , MHL / HDMI (Type A) , Network (RJ-45) , 2 x USB 2.0 (Type A) , Audio line-in (mini-jack) , Headphones (mini-jack) , Microphone (mini-jack)
Mechanical
Tilt
Tilt Angle
+12/+57.5
Flat Panel Mount Interface
75 x 75 mm
Security lock slot (cable lock sold separately), SmartStand
MTBF
70,000 hour(s)
28.9 Watt
Power Consumption Stand by
5.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
E-mail, Google Play, YouTube, Gallery, Music Player
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 56.3 cm - depth: 7.7 cm - height: 39.3 cm - weight: 5 kg , Without stand - width: 56.3 cm - depth: 5 cm - height: 35.9 cm
20 - 80%
98YC C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
98YC C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
98YC C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
98YC C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
98YC C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
98YC C2G Pro HDMI to VGA Converter In Stock £46.35
