Your basket is empty
Philips 227E6EDSD/00 22" 1920x1080 DVI HDMI Monitor
Quicklinx: BYZ5WS00 Mfr#: 227E6EDSD/00
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
£91.68 ex VAT
£110.01 inc VAT
Designed for you: the elegant Philips E-line monitor features SoftBlue technology to protect your eyes and deliver brilliant colorful images.
Philips E-line 227E6EDSD - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
ADS-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, MHL
Display Position Adjustments
Tilt
Glossy cherry black
51.1 cm x 21.2 cm x 40 cm
2.95 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, BSMI, GOST, SASO, SEMKO, DDC/CI, ISO 9241-307, WEEE, TCO Displays 6.0, SGS, cETLus
Display Type
Energy Class
Class A
31 kWh
21 W
Diagonal Size
21.5"
Panel Type
ADS-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, power off timer, sRGB colour management, HDCP, SmartImage Lite, SmartResponse, SmartContrast, power on timer, 4:3 in Wide, Touch Control, SoftBlue Technology
Glossy cherry black
51.1 cm x 21.2 cm x 40 cm - with stand
2.95 kg
VGA , DVI-D (HDCP) , MHL / HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
MTBF
30,000 hour(s)
Power Supply
External
15.52 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / Windows 8
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 21.2 cm - height: 40 cm - weight: 2.95 kg , Without stand - width: 51.1 cm - depth: 3.6 cm - height: 31.8 cm - weight: 2.58 kg
20 - 80%
BYZ5 C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.32
BYZ5 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.21
BYZ5 C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £8.17
BYZ5 C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £8.13
BYZ5 C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £40.05
BYZ5 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £7.82
BYZ5 C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £53.96
Response Time: 5ms
Speakers: None
Brand: Philips
Price Range Ex VAT: 50 - 100
