Philips 223V5LSB2/10 21.5" LED 1920x1080 VGA Black
Quicklinx: 91TYWS00 Mfr#: 223V5LSB2/10
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
More than 50 in stock
£59.88 ex VAT
£71.85 inc VAT
Enjoy vivid LED pictures on this Philips display. Equipped with SmartControl lite, it's a great choice!
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
  • Mercury Free
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • SmartContrast
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • 16:9 Full HD
    The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colours.
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 10000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast
Textured black, black hairline
50.3 cm x 21.3 cm x 37.6 cm - with stand
2.61 kg
VGA
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Power Supply
Internal
15.61 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Philips SmartControl Lite
Apple MacOS, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 50.3 cm - depth: 21.3 cm - height: 37.6 cm - weight: 2.61 kg ¦ Without stand - width: 50.3 cm - depth: 5 cm - height: 31.6 cm - weight: 2.35 kg
Environmental Standards
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
20 - 80%
Philips 223V5LSB2/10 21.5 Bundle deal on Philips 223V5LSB2/10 21.5" LED 1920x1080 VGA Black
£159.05
Accessories (5)
91TY StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
91TY StarTech.com Articulating Monitor Arm In Stock £101.86
91TY StarTech.com Dual Monitor Stand In Stock £69.36
91TY StarTech.com Cubicle Monitor Hanger In Stock £45.29
91TY StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
Other bundles (2)
91TY C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.55
91TY C2G VGA to Composite PC-TV Video Adapter In Stock £34.34
Response Time: 5ms
Speakers: None
Brand: Philips
Price Range Ex VAT: 50 - 100
