Philips 223V5LHSB2/00 22" 1920x1080 VGA HDMI Monitor
Equipped with HDMI and SmartControl Lite
Quicklinx: BYZGWS00 Mfr#: 223V5LHSB2/00
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
18 in stock
£68.92 ex VAT
£82.70 inc VAT
Enjoy vivid LED pictures on this Philips display. Equipped with HDMI outputs, it’s a great choice!
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
HDMI-ready for Full HD entertainment
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
LED technology for vivid colours
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
Easy display performance tuning with SmartControl Lite
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
Mercury Free eco-friendly display
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • Mercury Free eco-friendly display
  • Easy display performance tuning with SmartControl Lite
  • HDMI-ready for Full HD entertainment
  • SmartContrast for rich black details
  • 16:9 Full HD display for crisp, detailed images
Philips V-line 223V5LHSB2 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Textured black, black hairline
50.3 cm x 21.3 cm x 37.6 cm
2.61 kg
Plug and Play, FCC Class B certified, BSMI, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, EAC, cETLus, INMETRO
Display Type
Energy Class
Class B
32 kWh
22 W
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, 4:3 in Wide, Mercury free
50.3 cm x 21.3 cm x 37.6 cm - with stand
2.61 kg
VGA , HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
21.63 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Philips SmartControl Lite
Apple MacOS, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 50.3 cm - depth: 21.3 cm - height: 37.6 cm - weight: 2.61 kg , Without stand - width: 50.3 cm - depth: 5 cm - height: 31.6 cm - weight: 2.35 kg
20 - 80%
Philips 223V5LHSB2/00 22 Bundle deal on Philips 223V5LHSB2/00 22" 1920x1080 VGA HDMI Monitor
£168.09
Accessories (7)
BYZG StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.11
BYZG StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
BYZG StarTech.com Articulating Monitor Arm In Stock £101.86
BYZG StarTech.com Dual Monitor Stand In Stock £69.36
BYZG StarTech.com Cubicle Monitor Hanger In Stock £45.29
BYZG StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
BYZG StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Other bundles (3)
BYZG C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.05
BYZG C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.28
BYZG C2G VGA to Composite PC-TV Video Adapter In Stock £32.73
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 50 - 100
