Product
Philips 223S5LSB/00 22" 1920x1080 5ms VGA DVI LED Monitor
Quicklinx: CJ8KWS00 Mfr#: 223S5LSB/00
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
£81.29 ex VAT
£97.54 inc VAT
The Philips LED display using PVC, BFR free housing is ideal for eco-friendly productivity.
Philips S-line 223S5LSB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Textured black, black hairline
50.3 cm x 21.3 cm x 37.6 cm
2.61 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, TCO Displays, EAC, cETLus
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartContrast, 4:3 in Wide, Mercury free
50.3 cm x 21.3 cm x 37.6 cm - with stand
2.61 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hour(s)
15.64 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 50.3 cm - depth: 21.3 cm - height: 37.6 cm - weight: 2.61 kg , Without stand - width: 50.3 cm - depth: 5 cm - height: 31.6 cm - weight: 2.35 kg
ENERGY STAR Certified
20 - 80%
Philips 223S5LSB/00 22 Bundle deal on Philips 223S5LSB/00 22" 1920x1080 5ms VGA DVI LED Monitor
£181.05
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 50 - 100
