Philips 222B9T 24" 1920x1080 2ms DVI HDMI LED Monitor
Quicklinx: F72PWS00 Mfr#: 222B9T/00
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, DVI, VGA (HD-15)
12 In Stock
£252.62 ex VAT
£303.14 inc VAT
A sturdy, water-resistant and dust-resistant, anti-glare touchscreen monitor for flexible use anywhere, with articulating stand to fit angles you need. Offering simple and intuitive use across applications, greatly boosts productivity.
SmoothTouch display for natural, fluid touch response
This Philips display uses Projected capacitive 10-point touch technology for fluid response. You can fully utilise the new capabilities of touch-based applications and bring your older applications to life. Touch-type with 10 fingers or play exciting interactive games with your friends. Collaborate with colleagues interactively at work or school environment and increase your productivity and efficiency.
Monitor front surface meets IP65 for water and dust resistance
For less-than-perfect environments, you need a monitor that's designed to hold up to the splashes of water and dust that happen in the everyday world. Ingress Protection (IP) ratings defined in international standard IEC/EN 60529, are used to define levels of sealing effectiveness of electrical enclosures against intrusion from foreign bodies and moisture. This Philips display meets the international IP rating for water and dust resistance. It will hold up to the water splashes and dust that happen in the everyday world.
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
HDMI ensures universal digital connectivity
A HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
DisplayPort connection for maximum visuals
DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
SmartStand with adjustable angles, boosts productivity
Philips SmartStand allows for flexible adjustment of the screen. Its Z-type structure with smooth tilt, height adjustment and folding capabilities enables you to use it in various ergonomic positions. You can set the stand in upright position for better touch control or recline it backwards, making it easy for you to draw or annotate. It even allows you to put the screen almost flat on the table for some applications when required.
  • DisplayPort connection
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates- making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • SmartContrast
  • Flicker-Free technology
  • LowBlue Mode
  • SmoothTouch
  • SmartStand
  • HDMI Ready
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • Water- and dust-resistant
Philips B Line 222B9T - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Energy Class
Class E
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
15 W
Stylus, USB 3.1 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Textured black
51.5 cm x 22.7 cm x 39.4 cm
7.46 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, EPA, CU-EAC
Display Type
Energy Class
Class E
29 kWh
Diagonal Size
22"
Viewable Size
22"
Built-in Devices
USB 3.1 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Sync on Green, Lead-free, SmartContrast, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, EasyRead, sRGB Mode
Textured black
51.5 cm x 22.7 cm x 39.4 cm - with stand
7.46 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Stylus - touchscreen
VGA , DVI-D (HDCP) , DisplayPort , HDMI , USB 3.1 , USB 3.1 (fast charging) , USB upstream , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
SmartStand
Stylus (black)
1 x VGA cable , 1 x HDMI cable , 1 x USB-A to USB-B cable , 1 x audio cable
MTBF
70,000 hour(s)
Input Voltage
15 W
15 kWh/1000h
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand (highest position) - width: 51.5 cm - depth: 22.7 cm - height: 39.4 cm - weight: 7.46 kg , Without stand - width: 51.5 cm - depth: 4.5 cm - height: 31.7 cm - weight: 4.17 kg
Shipping Width
57.5 cm
Shipping Depth
16.1 cm
Shipping Height
42 cm
Shipping Weight
9.97 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 80%
Diagonal Size: 22in
Response Time: 1ms
Interfaces: HDMI
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
