Philips 221S6QYKMB/00 22" 1920x1080 DVI VGA Monitor
Quicklinx: BYQ1WS00 Mfr#: 221S6QYKMB/00
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£145.86 ex VAT
£175.03 inc VAT
The Philips ergonomic LED display using recycled materials and PVC, BFRfree housing is ideal for eco-friendly productivity. This improved display uses advanced AH-IPS panels resulting in superior color reproduction, response time and power consumption. AHIPS panels show consistent color even at 178 degrees wide angles and in pivot mode. With remarkable performance, AH-IPS is optimally suited for applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing.
  • Flicker-free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free technology applies an improved solution to regulate brightness and reduce flicker for more comfortable viewing.
  • SmartImage
    SmartImage is an exclusive Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance.
  • SmartContrast
    SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for the optimal digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional.
  • Low bezel-to-table height
    The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain.
  • Webcam
    Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel related costs.
  • Built-in stereo speakers
    A pair of high quality stereo speakers built into a display device.
  • DisplayPort connection
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities, it is fully capable to support fast data transfer. With this high performance and zero latency, you get the extremely fast imaging and refresh rates - making DisplayPort the optimal choice for not only general office or home use, but also for the demanding gaming and movies, video editing and more. It also keeps interoperability in mind via use of various adapters.
Philips S-line 221S6QYKMB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Power Consumption (On mode)
17.1 W
Microphone, 2.0 megapixel camera
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured black
51.1 cm x 22.7 cm x 38.4 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VCCI, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, CECP, EPA, cETLus, RCM, FCC Part 15 Class B
Display Type
17.1 W
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, Eco-Mode, SmartContrast, SmartImage, SmartPower, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free
Textured black
51.1 cm x 22.7 cm x 38.4 cm - with stand
4.9 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
150
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
MTBF
70,000 hour(s)
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.2 Watt
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 22.7 cm - height: 38.4 cm - weight: 4.9 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3 kg
ENERGY STAR Certified
20 - 80%
Philips 221S6QYKMB/00 22 Bundle deal on Philips 221S6QYKMB/00 22" 1920x1080 DVI VGA Monitor
£245.03
BYQ1 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.08
BYQ1 C2G HDMI to DisplayPort Adapter Converter In Stock £36.51
BYQ1 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.06
BYQ1 C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.09
BYQ1 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYQ1 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £22.77
BYQ1 C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £15.82
BYQ1 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.25
BYQ1 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.51
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 100 - 150
