This notebook docking display enables easy port replication. Expand your viewing workspace, keep peripherals connected, access the Internet, all with a single USB cable to your notebook.
Expand view with single cable
This large Philips display enables easy port replication for any notebook. Especially suitable for the ultra-thin notebooks with limited connectors, this display with built-in USB hub, Ethernet and stereo speakers enables you to transmit video, audio and connect to the Internet or intranet directly with a single cable USB connection. Using this advanced USB plug-and-play connection, you can now expand your desktop using both your NBPC and Philips display realestate without having to worry about cumbersome resolution adjustments or messing around with cables. -
USB hub for peripherals
You now have the option to connect a full sized keyboard and mouse to the Philips display's USB hub to improve your productivity. Simply connect your Notebook to this display with a single USB cable, and you are ready to utilize the additional peripherals such as the external HDD, camera, USB drive along with Full HD video, Audio and Internet functions. Should you prefer, you can of course still utilize your NBPC's keyboard and track pad as usual. -
AH-IPS technology
This Philips display uses advanced AHIPS panels utilizing improved structure resulting in superior color reproduction, response time and power consumption compared to other wide view angle panels. Unlike standard TN panels, AH-IPS panels exhibit the smallest amount of Gamma fluctuation and therefore are able to show consistent color even at 178/178 degrees and in pivot mode. With a remarkable performance, it is best suited to applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing. -
Flicker-Free technology
Because of the way brightness is controlled on LED-backlit screens, some users experience flicker on the screen, which causes eye fatigue. Philips Flicker-Free Technology applies an efficient solution to regulate brightness and reduce flicker for more comfortable viewing. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Low bezel-to-table height
Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
- Philips S-line 221S6QUMB - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- USB 2.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 14 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- USB
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black with black stand
- 51.1 cm x 22.7 cm x 48.3 cm
- 4.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, VCCI, C-Tick, ICES-003, SEMKO, TUV Ergo, PSB, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, E-Standby, KC, CECP, EPA, cETLus, CU-EAC
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 14 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- sRGB colour management, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free
- 51.1 cm x 22.7 cm x 48.3 cm - with stand
- 4.9 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- 3 x USB 2.0 , USB 2.0 upstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 150
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 70,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Windows 8
- Dimensions & Weight Details
- With stand - width: 51.1 cm - depth: 22.7 cm - height: 48.3 cm - weight: 4.9 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3.1 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
