Philips 221S6LCB/00 22" 1920x1080 DVI VGA Monitor
Quicklinx: BYPXWS00 Mfr#: 221S6LCB/00
Philips Flicker Free technology applies an ultimate solution to regulate brightness and reduce flicker for more comfortable viewing. LED allows for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
This LED features the SmartImage - an exclusive advanced Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. Philips advanced video processing combined with unique extreme dimming and backlight boosting technology results in vibrant images. The SmartErgo base is a monitor base that delivers ergonomic display comfort and provides cable management. SmartPower is an artificial intelligent technology which dynamically analyzes the content of the screen image to achieve power saving.
  • Zero mercury content
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • LED technology
    White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • Low bezel-to-table height
    Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
  • Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • SmartContrast ratio 20,000,000:1
    You want the LCD flat display with the highest contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight-boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent black level and accurate rendition of dark shades and colours. It gives a bright, lifelike picture with high contrast and vibrant colours.
  • SmartPower
    SmartPower is an artificial intelligent technology which dynamically analyses the content of the screen image to achieve power saving. The backlight intensity can be controlled automatically and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs
Philips S-line 221S6LCB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Voltage
Textured black
51.1 cm x 22.7 cm x 48.3 cm
4.64 kg
FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, J-MOSS, E-Standby, CECP, EPA, cETLus, RCM, CU-EAC
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartImage, SmartPower, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free
Textured black
51.1 cm x 22.7 cm x 48.3 cm - with stand
4.64 kg
DVI-D (HDCP) , VGA
Mechanical
Tilt Angle
-5/+20
Swivel Angle
150
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
MTBF
70,000 hour(s)
Input Voltage
Power Consumption (Typical)
17.08 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.2 Watt
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 22.7 cm - height: 48.3 cm - weight: 4.64 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 2.8 kg
20 - 80%
BYPX C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
