Enjoy brilliant performance from every angle with a full HD AH-IPS display! The Philips PowerSensor AH-IPS LED display using much post consumer recycled plastics and PVC, BFR-free housing is ideal for eco-friendly productivity.
AH-IPS technology
This Philips display uses advanced AH-IPS panels utilizing improved structure resulting in superior color reproduction, response time and power consumption compared to other wide view angle panels. Unlike standard TN panels, AH-IPS panels exhibit least amount of Gamma fluctuation and therefore are able to show consistent color even at 178/178 degrees and in pivot mode. With remarkable performance, it is well-suited for applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing. -
Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free Technology applies a solution to regulate brightness and reduce flicker for more comfortable viewing. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button! -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. -
Low bezel-to-table height
The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain. -
Built-in stereo speakers
A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design. -
USB Hub
Super Speed USB 3.0 deploys 5.0 gbit/s transfer rate, which is faster than USB 2.0 standard significantly reducing data transfer time saving you time and money. With more bandwidth, super speed transfer rates, better power management and superior overall performance, USB 3.0 delivers more possibilities for the large capacity storage devices. Sync-N-Go technology ensures you don't have to wait anymore for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backward compatible. -
LightSensor
Light Sensor uses a sensor to adjust the picture brightness depending on the room ambient light conditions for an optimized picture.
- Philips Brilliance P-line 221P6QPYES - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 14 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Internal
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black, textured silver
- 51.1 cm x 25.7 cm x 48.8 cm
- 5.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, cETLus
- Display Type
- Diagonal Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, PowerSensor, SmartResponse, SmartImage, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free
- 51.1 cm x 25.7 cm x 48.8 cm - with stand
- 5.6 kg
Audio
- Speakers - stereo - internal
- Output Power / Channel
- 2 Watt
- DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , Headphones , 4 x USB 3.0
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 15.45 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 51.1 cm - depth: 25.7 cm - height: 48.8 cm - weight: 5.6 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3.1 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
