Philips 221P6EPYEB/00 22" 1920x1080 VGA DVI Monitor
Quicklinx: BYM4WS00 Mfr#: 221P6EPYEB/00
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£171.27 ex VAT
£205.52 inc VAT
Designed for you, the Philips Brilliance monitor features SoftBlue LED technology to protect your eyes and deliver brilliant colorful images for maximum productivity.
  • SoftBlue technology
    Studies have shown that just as ultra-violet rays can cause eye damage, blue light rays from LED displays can cause eye damage and affect vision over time. SoftBlue LED technology uses a smart technology to reduce the harmful blue light waves without affecting the color or image of the display. SoftBlue LED technology is certified by international testing organizations SGS Labs and TUV Rheinland to reduce blue light and protect your eyes.
  • IPS-ADS technology
    IPS-ADS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-ADS displays give you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like office, photo, movie, game, economy to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The economy mode option offers you major power savings. All in real time with the press of a single button!
  • Flicker-free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips flicker-free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. SmartErgoBase The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional.
  • Built-in stereo speakers
    A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design.
  • PowerSensor
    PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life.
Philips Brilliance P-line 221P6EPYEB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Power Consumption (On mode)
13.84 W
USB 3.0 hub
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured black
51.1 cm x 25.7 cm x 48.8 cm
5.6 kg
Environmental Standards
TCO Certified ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, C-Tick, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, WEEE, CECP, cETLus
Display Type
13.84 W
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Ambient light sensor, Sync on Green, sRGB colour management, Eco-Mode, PowerSensor, SmartResponse, SmartImage, game mode, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free, SoftBlue Technology
Textured black
51.1 cm x 25.7 cm x 48.8 cm - with stand
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , Headphones , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
MTBF
70,000 hour(s)
Power Consumption Stand by
0.2 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 25.7 cm - height: 48.8 cm - weight: 5.6 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3.1 kg
ENERGY STAR Certified
20 - 80%
Philips 221P6EPYEB/00 22 Bundle deal on Philips 221P6EPYEB/00 22" 1920x1080 VGA DVI Monitor
£270.44
BYM4 C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.18
BYM4 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.57
BYM4 C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.37
BYM4 C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BYM4 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.89
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 150 - 300
