Designed for you, the Philips Brilliance monitor features SoftBlue LED technology to protect your eyes and deliver brilliant colorful images for maximum productivity.
SoftBlue technology
Studies have shown that just as ultra-violet rays can cause eye damage, blue light rays from LED displays can cause eye damage and affect vision over time. SoftBlue LED technology uses a smart technology to reduce the harmful blue light waves without affecting the color or image of the display. SoftBlue LED technology is certified by international testing organizations SGS Labs and TUV Rheinland to reduce blue light and protect your eyes. -
IPS-ADS technology
IPS-ADS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-ADS displays give you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like office, photo, movie, game, economy to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The economy mode option offers you major power savings. All in real time with the press of a single button! -
Flicker-free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips flicker-free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. SmartErgoBase The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. -
Built-in stereo speakers
A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design. -
PowerSensor
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life.
- Philips Brilliance P-line 221P6EPYEB - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Power Consumption (On mode)
- 13.84 W
- USB 3.0 hub
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 14 ms (typical); 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Textured black
- 51.1 cm x 25.7 cm x 48.8 cm
- 5.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, C-Tick, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, WEEE, TCO Certified Edge, CECP, TCO Displays 6.0, cETLus
- Display Type
- 13.84 W
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Ambient light sensor, Sync on Green, sRGB colour management, Eco-Mode, PowerSensor, SmartResponse, SmartImage, game mode, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free, SoftBlue Technology
- Textured black
- 51.1 cm x 25.7 cm x 48.8 cm - with stand
- 5.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , Headphones , 4 x USB 3.0
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- MTBF
- 70,000 hour(s)
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.2 Watt
- On / Off Switch
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
- Dimensions & Weight Details
- With stand - width: 51.1 cm - depth: 25.7 cm - height: 48.8 cm - weight: 5.6 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3.1 kg
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £96.99 | in stock |
£268.26
C2G 1m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £7.95 |
C2G 2m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £9.31 |
C2G 5m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £16.89 |
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL | In Stock | £10.82 |
C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter | In Stock | £5.00 |
C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter | In Stock | £7.59 |
C2G USB to DVI Adapter Up To 2048 x 1152 | In Stock | £38.98 |
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £8.65 |
C2G Pro DVI-D to VGA Converter - Video converter - Black | In Stock | £52.51 |
