Product
Philips 221B6QPYEB 21.5" 1920x1080 IPS Monitor
Quicklinx: 9W5RWS00 Mfr#: 221B6QPYEB/00
Get crisp images, efficient performance with PowerSensor saves energy! The Philips PowerSensor AH-IPS LED display using much post consumer recycled plastics and PVC, BFR-free housing is ideal for eco-friendly productivity.
  • AH-IPS technology
    This Philips display uses advanced AH-IPS panels utilizing improved structure resulting in superior color reproduction, response time and power consumption compared to other wide view angle panels. Unlike standard TN panels, AH-IPS panels exhibit least amount of Gamma fluctuation and therefore are able to show consistent color even at 178/178 degrees and in pivot mode. With remarkable performance, it is well-suited for applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing.
  • Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free Technology applies the solution to regulate brightness and reduce flicker for more comfortable viewing.
  • SmartImage
    SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
  • SmartErgoBase
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional.
  • Low bezel-to-table height
    The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain.
  • Built-in stereo speakers
    A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design.
  • 4 Ports USB 2.0 Hub
    USB Hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, Web camera, PDA, Printer and many other devices which has USB connection available. The conveniently located USB 2.0 Hub on the monitor allows USB 2.0 signals to pass thru to the computer. Note that many devices like cameras and HDD may need to be powered On independently, as they have higher power requirements than the monitor USB Hub can provide.
Philips Brilliance B-line 221B6QPYEB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
Textured black
51.1 cm x 22.7 cm x 48.3 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays 6.0, cETLus
Display Type
Diagonal Size
21.5"
Built-in Devices
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, PowerSensor, SmartResponse, SmartContrast, SmartImage, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free
Textured black
51.1 cm x 22.7 cm x 48.3 cm - with stand
4.9 kg
Audio
Speakers - stereo - internal
Output Power / Channel
2 Watt
DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , Headphones , 4 x USB 2.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
14.79 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Philips SmartControl Premium
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 22.7 cm - height: 48.3 cm - weight: 4.9 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3.1 kg
ENERGY STAR Certified
20 - 80%
9W5R C2G HDMI to DisplayPort Adapter Converter In Stock £36.21
9W5R C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £21.89
9W5R C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £23.89
9W5R C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £22.57
9W5R C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £15.66
9W5R C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.05
