Product
Philips 221B6LPCB/00 22" 1920x1080 DVI Monitor
Quicklinx: BYPKWS00 Mfr#: 221B6LPCB/00
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£104.57 ex VAT
£125.48 inc VAT
The Philips PowerSensor LED display using 85% post consumer recycled plastics and PVC, BFR free housing is ideal for eco-friendly productivity.
Philips Brilliance B-line 221B6LPCB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Power Consumption (On mode)
17.3 W
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Textured black
51.1 cm x 22.7 cm x 48.3 cm
4.83 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, J-MOSS, TCO Certified Edge, E-Standby, CECP, EPA, cETLus, RCM, CU-EAC
Display Type
17.3 W
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, PowerSensor, SmartContrast, SmartImage, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free, Zero power switch
Textured black
51.1 cm x 22.7 cm x 48.3 cm - with stand
4.83 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , Audio line-in , 4 x USB 2.0 downstream , Headphones , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
150
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
MTBF
70,000 hour(s)
Power Consumption Stand by
0.3 Watt
On / Off Switch
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 22.7 cm - height: 48.3 cm - weight: 4.83 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 2.99 kg
ENERGY STAR Certified
20 - 80%
Philips 221B6LPCB/00 22 Bundle deal on Philips 221B6LPCB/00 22" 1920x1080 DVI Monitor
£201.56
BYPK C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.95
BYPK C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.31
BYPK C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.89
BYPK C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £10.82
BYPK C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BYPK C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.59
BYPK C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £38.98
BYPK C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.65
BYPK C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £52.51
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 100 - 150
