Philips 220B4LPYCG/00 22" 1680x1050 DVI VGA Monitor
Quicklinx: BYPMWS00 Mfr#: 220B4LPYCG/00
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£146.40 ex VAT
£175.68 inc VAT
LEDs are solid state devices which light up to full, consistent brightness faster saving startup time. LEDs are free from mercury content which allows for eco-friendly recycling and disposal process. LEDs allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs and prolonging monitor life. DisplayPort is a digital link from PC to monitor without any conversion. With high performance and zero latency, you get fast imaging and refresh rates - making DisplayPort a great choice for not only general office or home use, but also for the demanding gaming and movies, video editing and more. It also keeps interoperability in mind via use of various adapters. The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain. SmartImage is an exclusive Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. This Philips monitor housing is free from brominated flame retardant and polyvinyl chloride.
  • LED technology
    White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
  • PowerSensor
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life
  • Zero power consumption
    At the flick of the 0 watt hard switch, which is conveniently located at the back of the monitor, you can completely cut off your monitor from AC power. This results in zero power consumption, reducing your carbon footprint even further
  • 2 Ports USB 2.0 HUB
    USB Hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, Web camera, PDA, Printer and many other devices which have USB connection available. The conveniently located USB 2.0 Hub on the monitor allows USB 2.0 signals to pass through to the computer. Note that many devices like cameras and HDD may need to be powered On independently, as they have higher power requirements than the monitor USB Hub can provide.
  • DisplayPort
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates- making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
Philips Brilliance B-line 220B4LPYCG - LED monitor - 22"
LED-backlit LCD monitor - 22"
Power Consumption (On mode)
18.84 W
USB Hub
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured grey
50.4 cm x 22.7 cm x 50.9 cm
5.2 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, SEMKO, TUV Ergo, DDC/CI, Lead-Free, WEEE, cETLus, CU-EAC
Display Type
18.84 W
Diagonal Size
22"
Built-in Devices
USB Hub
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage, Smart Ergo base, BFR/PVC-free, Mercury free, Zero power switch
Textured grey
50.4 cm x 22.7 cm x 50.9 cm - with stand
5.2 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , DVI-D , 2 x USB 2.0 , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
MTBF
40,000 hour(s)
11.4 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 50.4 cm - depth: 22.7 cm - height: 50.9 cm - weight: 5.2 kg , Without stand - width: 50.4 cm - depth: 5.9 cm - height: 34.9 cm - weight: 3.38 kg
TCO Certified
ENERGY STAR Certified
20 - 80%
BYPM C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.97
BYPM C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £21.83
BYPM C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYPM C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £22.51
BYPM C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £15.65
BYPM C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.02
BYPM C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.34
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 100 - 150
