Philips 22" LED 1680 x 1050 Monitor 16:10 1000:1 Vesa 100 x 100
Quicklinx: 98JJWS00 Mfr#: 220V4LSB/00
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 5ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
£94.11 ex VAT
£112.93 inc VAT
Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with SmartControl lite, it's a great choice!
  • Mercury Free
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • SmartContrast
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • Energy Star 5.0
    Energy Star is a US EPA sponsored energy efficiency programme also adopted by many other countries. Energy Star certification ensures that you are buying a product which meets the latest power efficiency standards and which operates with maximum power efficiency at all operational levels. New Philips monitors are certified for Energy Star 5.0 specifications and meet or exceed the standard. For example, in sleep mode Energy Star 5.0 requires less than 1 Watt power consumption, whereas Philips monitors consume less than 0.5 Watts.
Philips V-line 220V4LSB - LED monitor - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Textured black, glossy black
51.2 cm x 21.3 cm x 41.6 cm
3.66 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, BSMI, GOST, cUL, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Display Type
Diagonal Size
22"
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, sRGB colour management, HDCP, SmartContrast
51.2 cm x 21.3 cm x 41.6 cm - with stand
3.66 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
16.52 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Philips SmartControl Lite
Dimensions & Weight Details
With stand - width: 51.2 cm - depth: 21.3 cm - height: 41.6 cm - weight: 3.66 kg , Without stand - width: 51.2 cm - depth: 4.8 cm - height: 34.8 cm - weight: 3.32 kg
ENERGY STAR Certified
20 - 80%
Philips 22 Bundle deal on Philips 22" LED 1680 x 1050 Monitor 16:10 1000:1 Vesa 100 x 100
£193.28
98JJ C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.82
98JJ C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £11.09
98JJ C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.58
98JJ C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
98JJ C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.49
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 50 - 100
