Your basket is empty
Philips 22" Black LED Monitor Full HD 2 x 2W Speakers Height ad
Quicklinx: DFQDWS00 Mfr#: 223S7EHMB/00
More than 50 in stock
£106.32 ex VAT
£127.58 inc VAT
Our S Line monitor delivers business efficiency. A wide-view IPS display with SoftBlue technology is great for easy-on-the-eyes productivity. The height-adjustable, frameless display allows for tiling multiple monitors for an expanded view.
Philips S-line 223S7EHMB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Contrast Ratio
20000000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Textured black
49 cm x 20.2 cm x 45.5 cm
4.51 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, ICES-003, SEMKO, CCC, PSB, DDC/CI, RoHS, ISO 9241-307, WEEE, EPA, TCO Displays, cETLus, CU-EAC
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, SmartImage, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, SoftBlue Technology, EasyRead, 68% NTSC (CIE 1931) colour gamut
Textured black
49 cm x 20.2 cm x 45.5 cm - with stand
4.51 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
350
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 49 cm - depth: 20.2 cm - height: 45.5 cm - weight: 4.51 kg , Without stand - width: 49 cm - depth: 4.5 cm - height: 29.6 cm - weight: 2.63 kg
ENERGY STAR Certified
20 - 80%
Brand: Philips
Price Range Ex VAT: 100 - 150
